rhoPimpleFoam - airflow through plenum - unstable residuals
Old   February 12, 2021, 12:53
Default rhoPimpleFoam - airflow through plenum - unstable residuals
OisinOC is on a distinguished road
I am trying to use rhoPimpleFoam to simulate airflow through some small ducts. I have 3D printed and measured the pressure drop for a square 90 degree bend, a round 90 degree bend and now a plenum like bend in the duct. My round bend had a good match for pressure drop and the square was reasonable but the plenum model seems very unstable when I view the residuals.
I think the problem might be that because the air spreads out as it enters the plenum and slows down there a wider range of velocities and my model is not set up correctly to handle it.
I've attached the case files but the mesh is too big to attach. Can anyone suggest how I might improve it?
OisinOC is offline   Reply With Quote
air flow analysis, duct flow, rhopimplefoam
Cannot find functionObject file residuals vava10 OpenFOAM Pre-Processing 2 November 14, 2020 13:21
pimpleFoam, rhoPimpleFoam unstable at small Courant numbers (time-steps) peob OpenFOAM Running, Solving & CFD 18 November 13, 2020 14:56
Simulation of the airflow through a bunch of little balls RobertW FLUENT 14 April 5, 2020 18:38
motorBike Residuals for SST k-omega... and mine JR22 OpenFOAM Running, Solving & CFD 6 August 1, 2013 10:08
judging convergence through residuals MachZero Main CFD Forum 7 December 25, 2012 13:18
