Adding pressure-dependent heat source
Old   March 2, 2021, 23:27
Jonathan Wells
jdw135 is on a distinguished road
Originally Posted by HPE View Post
Let's see what we can do during the next week. (At least something for you to progress further rather than a complete solution.)
I've now done quite a bit more reading and I think I can do what I need with a scalarCodedSource. My only problem is that I'm not sure how to implement it, and if my code is doing what I want it to do.
First, do I make a file called "fvOptions" in the /system folder, or do I add this code to the controlDict file in the functions section? Looking at the OpenFOAM API here
https://www.openfoam.com/documentati...e.html#details
it says to put it in the controlDict file. When I do this, the case runs as normal, but there is no difference in the output. I am wondering if there is a problem with my code that is causing an issue. Here is my code:
energySource
        type            scalarCodedSource;
        active          yes;
        scalarCodedSourceCoeffs
            selectionMode   all;
            fieldNames      (h);
            name            sourceTime;
            codeInclude
            codeCorrect
                Pout<< "**codeCorrect**" << endl;
            codeAddSup
                const Time& time = mesh().time();
                const volScalarField& rhoS = mesh_.lookupObject<volScalarField>("rho");
                const volVectorField& uS = mesh_.lookupObject<volVectorField>("U");
                const volScalarField& pS = mesh_.lookupObject<volScalarField>("p");
                const vectorField& C = mesh_.C();
	        const scalarField& V = mesh_.V();
                scalarField& SoS = sqrt(1.4*(pS/rhoS));
                scalarField& mach = uS/SoS;
                scalarField& qq = -(pS*(1-(mach*mach))1005)/(1.4*(mach*mach)*287.058);
                scalarField& heSource = eqn.source();
                heSource += fvc::ddt(qq);
            codeSetValue
                Pout<< "**codeSetValue**" << endl;
            // Dummy entry. Make dependent on above to trigger recompilation
            code
                $codeInclude
                $codeCorrect
                $codeAddSup
                $codeSetValue
        sourceTimeCoeffs
            // Dummy entry
I tried making an "fvOptions" file, but I kept getting an error about "name" not being found. Can someone please help with this? There isn't a lot of documentation and I'm pulling my hair out here.
jdw135 is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
