volume fraction problem in multiphaseEulerFoam
Old   February 9, 2021, 09:25
Default volume fraction problem in multiphaseEulerFoam
Vishal
vishalgarg474 is on a distinguished road
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Calculating face flux field phi.waterdia1
Selecting diameterModel for phase waterdia1: constant
Calculating face flux field phi.waterdia2
Selecting diameterModel for phase waterdia2: constant
Calculating face flux field phi.air
Selecting diameterModel for phase air: constant
Selecting dragModel for phase waterdia2: blended
Selecting dragModel for phase waterdia2: SchillerNaumann
Selecting dragModel for phase air: SchillerNaumann
Selecting dragModel for phase waterdia1: blended
Selecting dragModel for phase waterdia1: SchillerNaumann
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
No MRF models present
DICPCG:  Solving for pcorr, Initial residual = 1, Final residual = 4.39209e-06, No Iterations 27
time step continuity errors : sum local = 6.23677e-13, global = 6.57419e-14, cumulative = 6.57419e-14
Courant Number mean: 3.72941e-06 max: 0.000135479
Starting time loop
deltaT = 1.2e-08
Time = 1.2e-08
PIMPLE: iteration 1
MULES: Solving for alpha.waterdia1
waterdia1 volume fraction, min, max = 2.982e-08 0 0.3
MULES: Solving for alpha.waterdia2
waterdia2 volume fraction, min, max = 1.988e-08 0 0.2
MULES: Solving for alpha.air
air volume fraction, min, max = 1 0 1
Phase-sum volume fraction, min, max = 1 0 1
waterdia1 volume fraction, min, max = 5.964e-08 0 0.3
waterdia2 volume fraction, min, max = 3.976e-08 0 0.2
Hey Guys, I am facing this error in multiphaseEulerFoam.
I am trying to analyze a water spray using this solver with air and two other phases for water with different droplet diameter. The source code of multiphaseEulerFoam is not completely executed and stops before zonePhaseVolumes.H (or Maybe it stops within the zonePhaseVolumes.H file).
As I understood, the fluid.solve() command is executed. Because the print statement in multiphasesystem.c solve and then solveAlphas is printed.
I am attaching my case folder as a zip file. Could you please help me understand the error or tell me why is the code stopping before the entire source code of multiphaseEulerFoam is executed?
Thank you in advance.
vishalgarg474 is offline   Reply With Quote
Old   February 9, 2021, 17:17
Vishal
I found the problem.
The sum of volume fractions was not 1 at the boundary.
Old   September 15, 2021, 17:19
Eslam Reda
Eslam Reda is on a distinguished road
Boss
Eslam Reda is offline   Reply With Quote
interfacialmodels, multiphaseeulerfoam, multiphasesystem, spray, volume fraction
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
interFoam wave propagation and explosion of Courant number and residuals ChiaraViola OpenFOAM Running, Solving & CFD 1 June 26, 2019 06:36
multiphaseEulerFoam high Courant number Frenk_T OpenFOAM 5 November 24, 2016 04:23
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 17:12
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
