How to set up the multiPhaseEulerFoam for two or more solid phases |
Dyrney
Rep Power: 14 ![]() |
Dear,
I would like to know if someone could help me with how to set up the "multiphaseEulerFoam" solver in the case of three phases, two solid phases (solid_1 and solid_2) and an air phase. I am facing some problems in setting up the "kinetic theory of granular flow" (e.g., restitution coefficient between solid_1 and solid_2; the granular viscous interaction between solid_1 and solid_2; etc) and the drag force (in "phaseProperties" file) between solid_1 and solid_2. Thanks so much. P.S. I am using OpenFOAM 8 |
Utkan Caliskan
Rep Power: 12 ![]() |
Current kineticTheory model of multiphaseEulerFoam doesn't support the interaction between two moving solid phases.
Dyrney
drag model, multiphaseeulerfoam, phaseproperties, three phases, two solid phases |
multiphaseEulerFoam - the velocity fields of phases blows up | mk1 | OpenFOAM Running, Solving & CFD | 0 | August 4, 2017 05:32 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
How to set 2 phases in Fluent | Heat Pipe | FLUENT | 4 | November 1, 2011 01:08 |
How to show the transient case? | H.P.LIU | Phoenics | 7 | July 13, 2010 04:31 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
