Sudden stop of heating - convergence problem?
Old   February 2, 2021, 05:34
Default Sudden stop of heating - convergence problem?
PSander is on a distinguished road
I simulate with OF8, chtMultiRegionFoam and Euler heating of a solid block, inside are two pipes filled with a fluid (water, velocity=0), every region has the same temperature.
The upper surface heats up the block and my goal is to know how much time does it need to heat up the whole block.
Unfortunately, after around 400.000 seconds the heating stops suddenly. The program does not crash, but in the next houndred thousand of seconds is almost no heating happening, which is implausible.
I expected wrong settings in fvSolution, so I tried different:
number of iterations (1-50),
relaxation Factors between 0.1 - 1,
nNonOrthogonalCorrectors from 0-2,
outerCorrectorResidualControl switched on and off.
all with the same outcome: at a certain temperature reached, the heating stops suddenly and almost completly.
Are there any settings influencing my problem, I could have forgotten or adjusted wrong?
Thank you in advance for your help!
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler; // Euler steadyState
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
laplacianSchemes
    default             none;
    laplacian(alpha,e)  Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    e
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.1;
    eFinal
        $e;
        tolerance        1e-06;
        relTol           0;
PIMPLE
    nNonOrthogonalCorrectors 0;
        e
            tolerance 1e-7;//5
            relTol 0;
relaxationFactors
    equations
        e           0.1;
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     chtMultiRegionFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         864000;
deltaT          1;
writeControl    adjustableRunTime;
writeInterval   3600;
purgeWrite      0;
writeFormat     ascii;
writePrecision  22;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  true;
maxCo           1;
functions
  #includeFunc "residuals_fluid"
  avT_fluid_outlet
      type            surfaceFieldValue;
      libs            ("libfieldFunctionObjects.so");
      log             yes;
      writeControl    runTime;
      writeInterval   3600;
      writeFields     false;
      surfaceFormat   none;
      regionType      patch;
      name            outlet;
      region 	      fluid;
      operation       areaAverage;
      fields
          T
  yPlus_fluid
    type            yPlus;
    executeControl  writeTime;
    writeControl    writeTime;
    region  fluid;
  wallHeatFlux_fluid
    type            wallHeatFlux;
    region  fluid;
  wallShearStress_fluid
    type            wallShearStress;
    region  fluid;
  turbulenceIntensity_fluid
    type            turbulenceIntensity;
    region  fluid;
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
PSander is offline   Reply With Quote
chtmulitregionfoam, convergance, euler
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
a problem with convergence in buoyantSimpleFoam skuznet OpenFOAM Running, Solving & CFD 6 November 15, 2017 13:12
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 11:47
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 14:43
