steadyState - Euler - different endresults
Old   January 30, 2021, 07:43
Default steadyState - Euler - different endresults
PSander is on a distinguished road
I calculate with OF8 and chtMultiRegionFoam. My geometry created with blockMesh is a simple square of x=6, y=3 and y=100 meters, thermophysical parameters are similar to sand.
The upper sirface has a constant heat flow of 303°K, the internal temperature is 293°K and all the other sides are of zero gradient.
My expectation is that after a certain time the whole block heated up to 303°K.
I run this model with steadyState, and I get what I expected.
I repeat it with Euler, and thought that the final results should be the same, but much slower.
But after a calculation of around 400.000 seconds the heating stops (not completly, but like 0.0000001°K per day), as you can see in the attached images.
1. Am I right that steadyState and Euler should have in the end the same result?
2. What could be my problem?
I suspect some setting in fvSolution or fvSchemes, so I attach the whole case and show you the code of those files.
Could you have a look and give me a hint? Thank you very much.
fvScheme for region soil
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler; // Euler steadyState
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
laplacianSchemes
    default             none;
    laplacian(alpha,e)  Gauss linear uncorrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         uncorrected;
fvSoultion for region soil
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    e
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0.1;
    eFinal
        $e;
        tolerance        1e-06;
        relTol           0;
PIMPLE
    nNonOrthogonalCorrectors 0;
    outerCorrectorResidualControl
        e
            tolerance 1e-5;
            relTol 0;
relaxationFactors
    equations
        e           0.5;
        eFinal        1;
controlDict
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     chtMultiRegionFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         864000;
deltaT          1;
writeControl    adjustableRunTime;
writeInterval   3600;
purgeWrite      0;
writeFormat     ascii;
writePrecision  22;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adjustTimeStep  true;
maxCo           1;
functions
  #includeFunc "residuals_fluid"
  avT_fluid_outlet
      type            surfaceFieldValue;
      libs            ("libfieldFunctionObjects.so");
      log             yes;
      writeControl    runTime;
      writeInterval   3600;
      writeFields     false;
      surfaceFormat   none;
      regionType      patch;
      name            outlet;
      region 	      fluid;
      operation       areaAverage;
      fields
          T
  yPlus_fluid
    type            yPlus;
    executeControl  writeTime;
    writeControl    writeTime;
    region  fluid;
  wallHeatFlux_fluid
    type            wallHeatFlux;
    region  fluid;
  wallShearStress_fluid
    type            wallShearStress;
    region  fluid;
  turbulenceIntensity_fluid
    type            turbulenceIntensity;
    region  fluid;
libs (
"libOpenFOAM.so"
"libsimpleSwakFunctionObjects.so"
"libswakFunctionObjects.so"
"libgroovyBC.so"
general fvSolution
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
PIMPLE
//    momentumPredictor yes;
    nOuterCorrectors 50;
    nCorrectors     2;
    consistent      true;
    pRefCell        0;
    pRefValue       0;
// ************************************************************************* //average_temp_euler.JPG
test_01.zip
PSander is offline   Reply With Quote
chtmultiregionfoam, euler, steadystate
steadyState - Euler - different endresults PSander OpenFOAM Running, Solving & CFD 0 January 30, 2021 06:18
When can I use Euler equations? CellZone Main CFD Forum 8 April 22, 2020 09:51
hard to convergent with SU2 4.0 for Euler adjoint Xianguu SU2 1 July 14, 2015 18:09
Steadystate Euler solver jelmer OpenFOAM Running, Solving & CFD 1 June 19, 2006 09:24
euler model CN FLUENT 0 July 4, 2005 17:35
