FOAM-EXTEND 4.1 pUCoupled + MRF + mixingPlane and GGI in Francis turbine application
Old   January 25, 2021, 10:32
Default FOAM-EXTEND 4.1 pUCoupled + MRF + and GGI in Francis turbine application
Andrea
andreaRocca is on a distinguished road
Hello Foamers,
I'am working with foam-extend 4.1 on Francis turbine flow.
The problem it is well know and already successful resolved using commercial codes as CFX, Numeca.
Foam-extend was attracting me already during my PhD time, but I was ESI addicted
Now, I have tried to simulate my turbine using the segregated solver fe4.1. The post-processing is still on going but results seem promising and the simulation converged very very good. So I'am quite happy with that.
Then I moved to the coupled solver, the one I'am really interested in. Unfortunately, I can not even get a piece of result.
At this point some details:
Configuration: 360° GV + 360° RU + DT.
Mesh: fully hexa multiblock (AG5+Omnis) and check mesh ok.
GV/RU : GGI
RU/DT GGI with bridgeOverlap set to true; (apparently there is some imperfection at the interface, which at CAD level it even not noticeble, btw before doing again the geometry and the mesh I want to be sure about numerics.)
I'm using MRF and coupledKEpsilon turbulence model + wall modeling.
BCs where U has inletOutlet p has outletInlet.
GV_INLET I used the rotatingWallTangentialVelocity
Running the case in parallel over 72 cores and 2 nodes and using scotch as decomposition method (actually I was not able to use metis or patch constrained). The patches at the interfaces are grouped into globalFaceZones.
Moving to fvSchemes, I started with slightly dissipative numerics moving to "second order upwind". At the beginning omega it is 1/10 of its real value.
fvSolution ... here it comes. I've tried AMG + VCycle +SAMG+ ILUC0 (+ many internal settings according to the information I've found in the papers suggested in foam-extend-4.1 release), BiCGStab, GMRES.
No way.
So, I'am not sure I'am doing all correctly in the setup. In particular I feel not comfortable with the fvSolution and decomposition method. Anyone could give me some tips about that in similar applications or even some references would be very appreciated.
Thank you!
andreaRocca is offline   Reply With Quote
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
