January 20, 2021, 17:19 |
Removing cells
sasi
Respected Sir,
I am using coldEngineFoam to solve flow compression in cylinder using piston and it is 2D simulation. I want to remove cells during compression as cells size decrease much after compression. I tried different methods like dynamicRefineFvMesh but solver is not reading the file. Please give me your suggestions to solve this problem. Thanks, |
dynamic mesh removal, remove cell |
problem with parallel calculations OF8 mpirun | otaolafr | OpenFOAM Programming & Development | 0 | January 5, 2021 07:33 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
[blockMesh] Removing interior cells | shd01 | OpenFOAM Meshing & Mesh Conversion | 3 | January 16, 2011 10:11 |
physical boundary error!! | kris | Siemens | 2 | August 3, 2005 00:32 |
