Improving the accuracy of result
Old   January 20, 2021, 13:22
Default Improving the accuracy of result
Kabir Shariff
Kbshariff is on a distinguished road
Hello Foamers,
I am relatively new to openfoam, my numerical case is a tidal turbine with actuator disc applied using fvOptions source. I use k-E turbulence model
I would like to improve the quality of my results (attached herewith is a comparison with a reference case using fluent).
My mesh is orthogonal mesh hence I used Gauss linear for the gradScheme..
below is my fvScheme
|  \\    /   O peration     | Version:  v2006                                 |
|   \\  /    A nd           | Website:  www.openfoam.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default             steadyState;
gradSchemes
    default             Gauss linear;
divSchemes
    default             none;
    div(phi,U)          Gauss linearUpwind grad(U);//Gauss upwind;	//bounded Gauss upwind;
    div(phi,epsilon)    Gauss upwind;					//Gauss upwind;	//bounded Gauss upwind;
    div(phi,k)          Gauss upwind;					//Gauss upwind;	//bounded Gauss upwind;
    div((nuEff*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default             Gauss linear limited corrected 0.33;
interpolationSchemes
    default            linear;
snGradSchemes
    default            corrected;	// limited corrected 0.33;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           GAMG;
        tolerance        1e-7;
        relTol           0.001;
        minIter          5;
        maxIter          100;
        smoother         GaussSeidel; // DIC; //DICGaussSeidel; //FDIC;
        nPreSweeps       1;
        nPostSweeps      3;
        nFinestSweeps    3;
        scaleCorrection true;
        directSolveCoarsest false;
        cacheAgglomeration on;
        nCellsInCoarsestLevel 50;    // 500
        agglomerator     faceAreaPair;
        mergeLevels      1;    // 3
    U
        solver           smoothSolver;
        tolerance        1e-6;
        relTol           0.01;
        nSweeps          1;
        maxIter	100;
    k
        tolerance        1e-6;
        relTol           0.01;
        nSweeps          1;
        maxIter	100;
    epsilon
        tolerance        1e-6;
        relTol           0.01;
        nSweeps          1;
        maxIter	100;
    p
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.001;
    U
        tolerance        1e-6;
        relTol           0.1;
        nSweeps          1;
    k
        tolerance        1e-6;
        relTol           0.1;
        nSweeps          1;
    epsilon
        tolerance        1e-6;
        relTol           0.1;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-3;
        U               1e-4;
        "(k|epsilon)"   1e-4;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.5; //0.7;
        epsilon         0.5; //0.7;
cache
    grad(U);
Thanks
Kbshariff is offline   Reply With Quote
Old   January 21, 2021, 04:38
shock77 is on a distinguished road
The result look quite good compared with your experiments. Most people would be satisfied with that I guess. I suppose you have achieved grid convergence before doing your final simulations. You can always increase the mesh denisty and do an LES or even an DNS. Also you can improve mesh density at walls and either resolve the boundary layer directly or you use e. g. the k-omega-SST model. There are like 1000 possibilties to do sth better but you have to decide whether you are satisfied with your results or not, since only you know what actually is important in you problem.
shock77 is offline   Reply With Quote
How to split air blade in CFX Post without loosing accuracy JonasII CFX 7 May 18, 2021 17:54
Does a larger number of iterations for steady state gives better result? cfdnewb123 FLUENT 0 March 3, 2019 01:09
radiation module, no accuracy result Young FLUENT 0 February 18, 2009 05:11
accuracy of Discontinuous Galerkin Qu Kun Main CFD Forum 0 September 6, 2004 10:19
time accuracy test nat Main CFD Forum 0 April 2, 2003 00:24
