January 11, 2021, 15:03 |
Torque calculation on simpleFoam
Rep Power: 6 |
I am running a simulation of a radial fan with simpleFoam. I use "forces" library to compute the torque on the shaft. The problem is I get around 3 x the expected torque. I really don't understand because I reached the expect result on other calculation but this one. I am wondering if it could come from the turbulences parameters ? If anybody has an idea ??? fvSolution Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "(p|p_rgh|pcorr)" { solver GAMG; tolerance 1e-7; relTol 0.00001; minIter 5; maxIter 100; smoother GaussSeidel; // DIC; //DICGaussSeidel; //FDIC; nPreSweeps 1; nPostSweeps 3; nFinestSweeps 3; scaleCorrection true; directSolveCoarsest false; cacheAgglomeration on; nCellsInCoarsestLevel 50; // 500 agglomerator faceAreaPair; mergeLevels 1; // 3 } "(pFinal|p_rghFinal|pcorrFinal)" { $p; relTol 0; } U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-20; relTol 0.00001; maxIter 50; minIter 5; } "(k|omega)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-20; relTol 0.0000001; maxIter 50; minIter 5; } } SIMPLE { nNonOrthogonalCorrectors 3; consistent yes; pRefCell 0; pRefValue 0; nCorrectors 1; residualControl { p 1e-3; Uz 1e-3; omega 1e-3; k 1e-3; } } relaxationFactors { fields { p 0.4; } equations { U 0.7; k 0.5; omega 0.5; } } cache { grad(U); } // ************************************************************************* // controlDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // saveIter 50; application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 500; deltaT 1; writeControl timeStep; writeInterval $saveIter; purgeWrite 0; writeFormat ascii; writePrecision 7; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; functions { forcesBlades { type forces; libs (forces); log yes; patches (aubes); rho rhoInf; // Indicates incompressible log true; rhoInf 1.234; // Redundant for incompressible CofR (0 0 0); // Rotation around centre line of propeller pitchAxis (0 1 0); } yPlusPump { type yPlus; libs ("libfieldFunctionObjects.so"); writeControl timeStep; writeInterval $saveIter; patches ("fan wallinlet body"); } } // ************************************************************************* // fvSchemes Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } divSchemes { default none; // Use second-order accurate convection // Bounded schemes for steady-state solution div(phi,U) bounded Gauss linearUpwind grad(U); div((nuEff*dev2(T(grad(U))))) Gauss linear; div(div(phi,U)) Gauss linear; div(phi,k) bounded Gauss upwind; div(phi,omega) bounded Gauss upwind; } gradSchemes { // Limit gradient to improve stability when bad cells encountered // (0 = no limiting; 1 = do not exceed surrounding cells) default cellLimited Gauss linear 0.95; grad(p) Gauss linear; grad(p_rgh) Gauss linear; grad(k) cellLimited Gauss linear 0.9; grad(omega) cellLimited Gauss linear 0.9; } laplacianSchemes { // Limited explicit correction to the surface normal gradient, // for stability in highly non-orthogonal cells. // (0 = uncorrected, fully implicit; 1 = full correction) default Gauss linear limited 0.6; laplacian(DomegaEff,omega) Gauss linear limited 0.6; laplacian(DkEff,k) Gauss linear limited 0.6; } interpolationSchemes { default linear; } snGradSchemes { // Limited explicit correction to the surface normal gradient, // for stability in highly non-orthogonal cells. // (0 = uncorrected, fully implicit; 1 = full correction) default limited 0.6; } wallDist { method meshWave; } // ************************************************************************* // turbulenceProperties Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1912 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object turbulenceProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // //simulationType laminar; simulationType RAS; RAS { RASModel kOmegaSST; turbulence on; printCoeffs on; } // ************************************************************************* // |
simpleFoam fan calculation | Fouch | OpenFOAM Running, Solving & CFD | 1 | January 2, 2021 16:26 |
XFlow torque calculation problem, darrieus wind turbine | Cami_lo | CFD Freelancers | 0 | February 10, 2020 19:47 |
torque calculation | kestasposkus | CFX | 2 | September 18, 2018 10:05 |
Problem in Torque calculation | Achilleas | CFX | 21 | July 25, 2018 10:14 |
torque calculation | mach000 | CFX | 2 | April 14, 2010 05:00 |
