interFoam: Setting boundary conditions for a river
Old   January 3, 2021, 09:58
Default interFoam: Setting boundary conditions for a river
Deutschland
aelmoe is on a distinguished road
Hey all,
First of all: i have been looking for a solution quite a while in this forum and couldn't find a suitable answer.
I am currently setting up a case, where i want do depict the velocitys in a river where a discharge channel of an hydropowerplant rejoins the main river channel.
Presteps were blockMesh, surfaceFeatureExtract, snappyHexMesh and setFields.
I only have Input / Inlet data in m³/s hence i think i have to use the flowRateInletVelocity boundary for both my Inlets (1: main channel; 2: discharge channel) in 0/U.
As i view my resuluts after the solving, it seems like everything "flow" or "velocity" is going over the atmosphere patch.
so far i have tried to just set a volumetricFlowRate and switch the additonal properties extrapolateProfile as well as the value for the volumetricFlowRate on and off.
Do you have any recommendation, so that the velocity is flowing on the soil of my mesh (i named it for projectpurposes Diff_Ref)?
My code for U ist
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (1 0 0);
boundaryField
    inlet1
        type            flowRateInletVelocity;
        volumetricFlowRate constant 1.4;
        //value           uniform (1.4 0 0);
        extrapolateProfile  yes;
    inlet2
        volumetricFlowRate constant 0.6;
        //value           uniform (0.6 0 0);
        //extrapolateProfile  yes;
    outlet
        type            freestream;
        freestreamValue uniform (1 0 0);
    frontAndBack
        type            noSlip;
    soil
        type            noSlip;
    atmosphere
        type            pressureInletOutletVelocity;
        value           uniform (0 0 0);
    Diff_Ref
        type            slip;
my complete case can be seen here:
https://1drv.ms/u/s!AgK-q6eTTXN1xEDHd2pGFGA-l3hx?e=HHaZax
Thanks in advance,
aelmoe
aelmoe is offline   Reply With Quote
Old   January 3, 2021, 22:19
Amirhossein Taran
amirhosseintaran is on a distinguished road
Dear aelmoe , have you tried inlet-outlet bc ( for velocity and maybe alpha) for your atmospheric patch ?
amirhosseintaran is offline   Reply With Quote
Old   January 4, 2021, 04:38
Tobermory will become famous soon enough
From a quick check of your inlet boundaries, you have set the following for alpha:
    inlet1
        type            fixedValue;
        value           uniform 1;
    inlet2
        type            fixedValue;
        value           uniform 1;
i.e. setting alpha = 1 across the whole of the inlet patch. In other words, you are setting the water level to the top of the domain. The fixed volume flow boundary then controls the flow rate, and so it makes sense I think that the code fills the domain with water, from the inlets downward.
You need to do something more realistic with the water levels at the two inlets. Funkysetboundaryfield (part of swak4Foam) is a good tool for this, although you should also be able to do it with the vanilla distribution using some simple coding. Good luck.
Tobermory is offline   Reply With Quote
boundary conditions, flowratevelocity, interfoam, river
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
