rhoSimpleFoam terminates immediately on running
Old   December 31, 2020, 13:18
Unhappy rhoSimpleFoam terminates immediately on running
Greg Bizup
Gbiz123 is on a distinguished road
Hi, I am new to this community, CFD, and OpenFOAM. I'm mostly self taught so far, but I'm planning on studying it further in grad school.
I am trying to model a flow through a jet nozzle using OpenFOAM on Windows Subsystem for Linux. I successfully ran simpleFoam. The solver I want to try next, rhoSimpleFoam, quits after reading the thermophysicalProperties without sending an error message. I'm not sure what could be causing this. Any help would be appreciated. I've included screenshots of the problem, my mesh, and code blocks of my dictionaries.
Screenshot of the problem:
https://imgur.com/a/5pCYKfz
Screenshot of mesh:
https://imgur.com/eFe7LJC
thermophysicalProperties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            hePsiThermo;
    mixture         pureMixture;
    transport       sutherland;
    thermo          hConst;
    equationOfState perfectGas;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture // CO2 at room temperature (1293 K) estimated temperature for jet engine exhaust
    specie
        molWeight   44.01;
    thermodynamics
        Cp          1298; //J/kg K
        Hf           0;
    transport
        As          1.67212e-6; //Sutherland coefficient
        Ts          170.672;      //sutherland temperature
transportProperties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      transportProperties;
transportModel  Newtonian;
nu              .7424;
fvSolution:
solvers
    p
        solver          GAMG;
        smoother        GaussSeidel;
        tolerance       1e-7;
        relTol          0.1;
    "(U|k|omega|e|epsilon)"
        solver          smoothSolver;
        tolerance       1e-6;
        relTol          0.1;
        nSweeps         1;
SIMPLE
    residualControl
        p               1e-4;
        U               1e-4;
        "(k|omega|e|epsilon)"   1e-4;
    nNonOrthogonalCorrectors 0;
    pMinFactor      0.1;
    pMaxFactor      2;
relaxationFactors
    fields
        p               0.01;
        rho             0.01;
    equations
        U               0.5;
        e         0.1;
        epsilon         0.1;
        k               0.1;
        h               0.1;
        omega           0.1;
fvSchemes
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    limited         cellLimited Gauss linear 1;
    grad(U)         $limited;
    grad(k)         $limited;
    grad(omega)     $limited;
divSchemes
    default         none;
    div(phi,U)      bounded Gauss linearUpwind limited;
    turbulence      bounded Gauss upwind;
    energy          bounded Gauss linearUpwind limited;
    div(phi,k)      $turbulence;
    div(phi,omega)  $turbulence;
    div(phi,e)      $energy;
    div(phi,K)      $energy;
    div(phi,Ekp)    $energy;
    div(phid,p)     Gauss upwind;
    div((phi|interpolate(rho)),p)  bounded Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
fvOptions:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
limitT
    type       limitTemperature;
    min        0;
    max        3000;
    selectionMode all;
Cheers
Greg
Gbiz123 is offline   Reply With Quote
compressible, error, kepsilon, rhosimplefoam, thermophysical
ERROR when using rhoSimpleFoam in Helyx-OS spitchers OpenFOAM Running, Solving & CFD 7 March 29, 2022 11:56
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS JMosiezny OpenFOAM Installation 15 December 9, 2017 09:20
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. MBttR OpenFOAM Running, Solving & CFD 0 June 13, 2016 11:58
rhosimplefoam running problem aneshe OpenFOAM Running, Solving & CFD 4 May 21, 2010 12:33
Problem in running rhoSimpleFoam xqy OpenFOAM Running, Solving & CFD 1 April 24, 2010 12:14
