laser simulation by icoReactingMultiphaseInterFoam
Like Tree5Likes
Old   June 10, 2022, 03:58
Teresa
TeresaT is on a distinguished road
Hey Dhar
yes, it is included. In the thermophysicalProperties.x files you can find it as Hf under thermodynamics.
Regards,
Teresa
TeresaT is offline   Reply With Quote
Old   July 6, 2022, 07:33
Default Questions about LaserDTRM model
  #42
Luca Luberto
LucaL is on a distinguished road
Hello all,
since some time I work within the icoReactingMultiphaseInterFoam solver with the laserDTRM model.
In doing so, I have come up with a few questions.
These are related to the code "DTRMParticle.C" in lines 222 to 226.
Question 1:
Is there a literature reference to this equation? How was the equation for the DTRM model transformed to the present equation?
Question 2:
The part: (ds*e*sigma*pow4(T)/mathematical:i)/ (1 + ds*a) reminds strongly of the radiation of a gray body.
Does the multiplication (ds*e)/(1 + ds*a) therefore establish the relation to a black body? If so, with certain choice of the coefficients e and a, the body could radiate more strongly than a black body.
Question 3:
What is the significance of the coefficient E? In the code "localDensityAbsorptionEmission.H" in line 72 and 73 this is titled as emission contributions.
Through several simulations (with significantly increased ECoeff values, up to 1e12), I could not find any change in the temperature profile within a solid metal.
Hopefully the questions were understandable.
Looking forward to answers and new thoughts.
Greetings!
LucaL is offline   Reply With Quote
Old   September 30, 2022, 01:37
Default Regardings laser heat source
  #43
VINIT
VINIT is on a distinguished road
Hello Everyone
I am trying to simulate melt pool dynamics in OpenFOAM using IcoReactingMultiphaseInterfoam but I am not getting the correct results. The temperature is not what it should be and the laser is not applied to top surface. I am attaching the results.
Could anyone help me what is wrong?
VINIT is offline   Reply With Quote
Old   September 30, 2022, 09:59
Krapf is on a distinguished road
Originally Posted by VINIT View Post
[...] the laser is not applied to top surface.
That's how it is supposed to work. In the radiationProperties you define the absorption coefficient [1/m]. If you choose a value large enough, you will see that the laser beam does not penetrate the material completely. This will also change the temperature, because more energy is absorbed in fewer cells.
Krapf is offline   Reply With Quote
Old   September 30, 2022, 15:01
Default Radiation properties
  #45
VINIT
Hello Krapf
Thanks for the response. I tried your suggestion, and I am getting the melt pool but still the temperature is still low. It should be around 3000 K but I am getting 440 K. What am I doing wrong?
I have attached my radiation file and the result.
Thanks
Old   October 1, 2022, 15:30
Do you get the expected values when you plot the absorbed power in ParaView?
Old   October 3, 2022, 18:13
VINIT
How do you check the absorbed power?
Old   October 4, 2022, 06:06
IIRC the Q field (power/volume) is written. If so you can plot it in ParaView and use the "Integrate Variables" filter to get the power (you'll get one value).
EDIT: If you use the "Mesh Quality" filter and select the volume as measure, you can use the calculator to multiply Q by the volume of each cell. Then you can look at the distribution of the power.
Old   October 20, 2022, 13:43
VINIT
Thanks for the reply. I was able to get correct temperature. I had to set the correct sigma value for laser. Now I am trying to incorporate convection, vaporization, radiation losses. Do you have any idea about any of these?
Old   October 26, 2022, 03:36
nixiaonan is on a distinguished road
What is your sigma value?thank you。
nixiaonan is offline   Reply With Quote
Old   October 26, 2022, 11:59
For mass transfer you can use Lee, kineticGasTheory (https://www.openfoam.com/news/main-n...er-and-physics) or interfaceHeatResistance (https://www.openfoam.com/news/main-n...rs-and-physics).
Old   November 10, 2022, 01:13
Default Powder spreading tutorial
  #52
VINIT
Hello Everyone
I am trying to simulate LBPF and I have developed the custom solver and geometry. I want to add powder layer but I don't have much knowledge about it. Do you have any tutorial that you can share to create powder layer using CFD-DEM. I have coupled liggghts openfoam but I am not able to find any tutorial for the same.
Thanks in advance
Laser welding simulation using OpenFoam yeokiwi CFD Freelancers 2 June 4, 2017 03:49
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Simulation of high pressure diesel injector - all phases compressible with cavitation fivos CFX 4 July 30, 2015 07:48
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 13:27
Simulation of Laser Drilling in FLUENT JB FLUENT 0 November 20, 2006 01:12
