December 27, 2020, 18:42 |
Multiple Injector sprayFoam openFOAM 211
Marcos Gutiérrez
Rep Power: 6 |
Hi everyone,
I am trying to simulate two opposed injector nozzle spray in a rectangular chamber. The solver sprayFoam runs but, only one spray is displayed in Paraview. Here is the code and what I added is commented. Can you tell me please how to insert the code to simulate 2 injectors in openFOAM 211 CAELinux 2013 with sprayFoam and injectionModel: coneNozzleInjection? Thank you for any advice. Marcos Below the code: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class dictionary; location "constant"; object SprayCloudProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solution { active true; coupled true; transient yes; cellValueSourceCorrection on; sourceTerms { schemes { rho explicit 1; U explicit 1; Yi explicit 1; hs explicit 1; } } interpolationSchemes { rho cell; U cellPoint; mu cell; T cell; Cp cell; p cell; } integrationSchemes { U Euler; T analytical; } } constantProperties { parcelTypeId 1; rhoMin 23.23; //was 1e-15 TMin 310; //was 200 pMin 6100000; //was 1000 minParticleMass 1e-15; rho0 834.197; //was 1000 T0 310; //was 320 Cp0 4187; youngsModulus 1e9; poissonsRatio 0.35; epsilon0 1; f0 0.5; Pr 0.7; Tvap 310; //was273 Tbp 335.3; constantVolume false; } subModels { particleForces { sphereDrag; } injectionModel coneNozzleInjection; dispersionModel none; patchInteractionModel standardWallInteraction; heatTransferModel RanzMarshall; compositionModel singlePhaseMixture; phaseChangeModel liquidEvaporationBoil; surfaceFilmModel none; atomizationModel none; breakupModel ReitzDiwakar; // ReitzKHRT; stochasticCollisionModel none; radiation off; coneNozzleInjectionCoeffs { SOI 0; massTotal 7.7e-5; //was 6.0e-6 parcelBasisType mass; injectionMethod disc; flowType flowRateAndDischarge; outerDiameter 4.0e-4; //was 1.9e-4; innerDiameter 0; duration 1.6e-3; //was 1.25e-3; position ( 0 0.4995 0 ); direction ( 0 -1 0 ); parcelsPerSecond 20000000; flowRateProfile table ( (0.0000 0.044118) (0.0001 0.058824) (0.0002 0.044118) (0.0003 0.049020) (0.0004 0.053992) (0.0005 0.058824) (0.0006 0.058824) (0.0007 0.053992) (0.0008 0.044118) (0.0009 0.049020) (0.0010 0.049020) (0.0011 0.053992) (0.0012 0.049020) (0.0013 0.049020) (0.0014 0.058824) (0.0015 0.049020) (0.0016 0.049020) ); //the whole flow rate was modified Cd constant 0.8; //was 0.9 thetaInner constant 0.0; thetaOuter constant 10.0; sizeDistribution { type RosinRammler; RosinRammlerDistribution { minValue 1e-06; maxValue 0.00015; d 0.00015; n 3; } } } standardWallInteractionCoeffs { type rebound; } RanzMarshallCoeffs { BirdCorrection true; } singlePhaseMixtureCoeffs { phases ( liquid { C7H16 1; //was C7H16 } ); } liquidEvaporationBoilCoeffs { enthalpyTransfer enthalpyDifference; activeLiquids ( C7H16 ); //was C7H16 } ReitzDiwakarCoeffs { solveOscillationEq yes; Cbag 6; Cb 0.785; Cstrip 0.5; Cs 10; } /* ReitzKHRTCoeffs { solveOscillationEq yes; B0 0.61; B1 40; Ctau 1; CRT 0.1; msLimit 0.2; WeberLimit 6; } */ TABCoeffs { y0 0; yDot0 0; Cmu 10; Comega 8; WeCrit 12; } } /************************************************** *********** a new submodel is added with another position of the nozzle ************************************************** ***********/ { particleForces { sphereDrag; } injectionModel coneNozzleInjection; dispersionModel none; patchInteractionModel standardWallInteraction; heatTransferModel RanzMarshall; compositionModel singlePhaseMixture; phaseChangeModel liquidEvaporationBoil; surfaceFilmModel none; atomizationModel none; breakupModel ReitzDiwakar; // ReitzKHRT; stochasticCollisionModel none; radiation off; coneNozzleInjectionCoeffs { SOI 0; massTotal 7.7e-5; //was 6.0e-6 parcelBasisType mass; injectionMethod disc; flowType flowRateAndDischarge; outerDiameter 4.0e-4; //was 1.9e-4; innerDiameter 0; duration 1.6e-3; //was 1.25e-3; position ( 0 0.0005 0 ); direction ( 0 1 0 ); parcelsPerSecond 20000000; flowRateProfile table ( (0.0000 0.044118) (0.0001 0.058824) (0.0002 0.044118) (0.0003 0.049020) (0.0004 0.053992) (0.0005 0.058824) (0.0006 0.058824) (0.0007 0.053992) (0.0008 0.044118) (0.0009 0.049020) (0.0010 0.049020) (0.0011 0.053992) (0.0012 0.049020) (0.0013 0.049020) (0.0014 0.058824) (0.0015 0.049020) (0.0016 0.049020) ); //the whole flow rate was modified Cd constant 0.8; //was 0.9 thetaInner constant 0.0; thetaOuter constant 10.0; sizeDistribution { type RosinRammler; RosinRammlerDistribution { minValue 1e-06; maxValue 0.00015; d 0.00015; n 3; } } } standardWallInteractionCoeffs { type rebound; } RanzMarshallCoeffs { BirdCorrection true; } singlePhaseMixtureCoeffs { phases ( liquid { C7H16 1; //was C7H16 } ); } liquidEvaporationBoilCoeffs { enthalpyTransfer enthalpyDifference; activeLiquids ( C7H16 ); //was C7H16 } ReitzDiwakarCoeffs { solveOscillationEq yes; Cbag 6; Cb 0.785; Cstrip 0.5; Cs 10; } /* ReitzKHRTCoeffs { solveOscillationEq yes; B0 0.61; B1 40; Ctau 1; CRT 0.1; msLimit 0.2; WeberLimit 6; } */ TABCoeffs { y0 0; yDot0 0; Cmu 10; Comega 8; WeCrit 12; } } cloudFunctions {} // ************************************************** *********************** // |
December 28, 2020, 10:12 |
Marcos Gutiérrez
Rep Power: 6 |
SOLVED!
Hi every one, I found the solution: coneNozzleInjection only works fro 1 Injector or 1 nozzle hole. You have to change the injectionModel to coneInjection below the corrected sprayCloudProperties /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class dictionary; location "constant"; object SprayCloudProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solution { active true; coupled true; transient yes; cellValueSourceCorrection on; sourceTerms { schemes { rho explicit 1; U explicit 1; Yi explicit 1; hs explicit 1; } } interpolationSchemes { rho cell; U cellPoint; mu cell; T cell; Cp cell; p cell; } integrationSchemes { U Euler; T analytical; } } constantProperties { parcelTypeId 1; rhoMin 23.23; //was 1e-15 TMin 310; //was 200 pMin 6100000; //was 1000 minParticleMass 1e-15; rho0 834.197; //was 1000 T0 310; //was 320 Cp0 4187; youngsModulus 1e9; poissonsRatio 0.35; epsilon0 1; f0 0.5; Pr 0.7; Tvap 310; //was273 Tbp 335.3; constantVolume false; } subModels { particleForces { sphereDrag; } //injectionModel coneNozzleInjection; injectionModel coneInjection; dispersionModel none; patchInteractionModel standardWallInteraction; heatTransferModel RanzMarshall; compositionModel singlePhaseMixture; phaseChangeModel liquidEvaporationBoil; surfaceFilmModel none; atomizationModel none; breakupModel ReitzDiwakar; // ReitzKHRT; stochasticCollisionModel none; radiation off; //coneNozzleInjectionCoeffs coneInjectionCoeffs { SOI 0; massTotal 7.7e-5; //was 6.0e-6 parcelBasisType mass; injectionMethod disc; flowType flowRateAndDischarge; outerDiameter 4.0e-4; //was 1.9e-4; innerDiameter 0; duration 1.6e-3; //was 1.25e-3; //position ( 0 0.4995 0 ); //direction ( 0 -1 0 ); positionAxis //added ( //added (( 0 0.4995 0 ) ( 0 -1 0 )) //added (( 0 0.0005 0 ) ( 0 1 0 )) //added ); //added parcelsPerInjector 100000; //added parcelsPerSecond 100000; //modified was 10000000 flowRateProfile table ( (0.0000 0.044118) (0.0001 0.058824) (0.0002 0.044118) (0.0003 0.049020) (0.0004 0.053992) (0.0005 0.058824) (0.0006 0.058824) (0.0007 0.053992) (0.0008 0.044118) (0.0009 0.049020) (0.0010 0.049020) (0.0011 0.053992) (0.0012 0.049020) (0.0013 0.049020) (0.0014 0.058824) (0.0015 0.049020) (0.0016 0.049020) ); //the whole flow rate was modified Cd constant 0.8; //was 0.9 Umag constant 22.8; //added thetaInner constant 0.0; thetaOuter constant 10.0; sizeDistribution { type RosinRammler; RosinRammlerDistribution { minValue 1e-06; maxValue 0.00015; d 0.00015; n 3; } } } standardWallInteractionCoeffs { type rebound; } RanzMarshallCoeffs { BirdCorrection true; } singlePhaseMixtureCoeffs { phases ( liquid { C7H16 1; //was C7H16 } ); } liquidEvaporationBoilCoeffs { enthalpyTransfer enthalpyDifference; activeLiquids ( C7H16 ); //was C7H16 } ReitzDiwakarCoeffs { solveOscillationEq yes; Cbag 6; Cb 0.785; Cstrip 0.5; Cs 10; } /* ReitzKHRTCoeffs { solveOscillationEq yes; B0 0.61; B1 40; Ctau 1; CRT 0.1; msLimit 0.2; WeberLimit 6; } */ TABCoeffs { y0 0; yDot0 0; Cmu 10; Comega 8; WeCrit 12; } } cloudFunctions {} // ************************************************** *********************** // |
conenozzleinjection, injector, sprayfoam |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 04:19 |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 05:57 |
OpenFOAM parallel on multiple nodes | FerdiFuchs | OpenFOAM Running, Solving & CFD | 1 | March 4, 2016 18:36 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 20:00 |
