interFoam(s) from different version of OpenFOAM/foam-extend give different results
Old   December 26, 2020, 23:52
Default interFoam(s) from different version of OpenFOAM/foam-extend give different results
Pei Li
HectorLee is on a distinguished road
Hello, everyone,
Recently, I ran simulations using interFoam(s) from OpenFOAM-v1812 and foam-extend-4.0. Surprisingly, the results of 2D drainage in a capillary tube are different. Although the locations of the invading fluid front are almost the same, the locations of the contact line between fluids and wall are different (as figures show). It seems that the contact line in the simulation using OpenFOAM-v1812 moved faster than that in foam-extend, so the saturation value is also slightly higher. Both figures are for the fluid distribution at t = 0.0011s. Is there anyone knowing why it can happen? The simulations files can be downloaded from here:
https://drive.google.com/drive/folde...Ju?usp=sharing
Thanks lot.
HectorLee is offline   Reply With Quote
OpenFOAM.com versus OpenFOAM.org: Which version to use? wyldckat OpenFOAM 19 March 25, 2023 08:50
rasInterFoam appears to give erroneous results for “pd”. richard_kenny OpenFOAM Bugs 6 August 2, 2013 18:12
[swak4Foam] OpenFOAM 1.6 and 1.7 with interFoam, groovyBC give different strange results Arnoldinho OpenFOAM Community Contributions 7 December 9, 2010 17:29
why dynamic mesh method give wrong results? weiyang1980 Main CFD Forum 0 September 22, 2009 22:06
Must periodic oscillation give periodic results? zonexo Main CFD Forum 6 May 13, 2007 16:36
