Convergence problem with no slip BC simple foam- Actuator disk model
Old   December 18, 2020, 10:56
Default Convergence problem with no slip BC simple foam- Actuator disk model
Kabir Shariff
Kbshariff is on a distinguished road
Hi foamers,
I am having trouble with residuals convergence when I used no slip wall BC in simple foam.
I am simulating a tidal turbine using actuator disc model defined in fvOption in OFv2006.
My case converges with slip walls at the bottom of the domain after say aroud 3000 iteration, but when I used no slip ( because i am using a log profile at inlet for U and I). the residual is still constant for 60,000 iterrations ( about 16 hrs runtime).
I attached herewith by case files please
U/
internalField   uniform (0 0 0);
boundaryField
    inlet
     type            groovyBC;
     variables (
		"zp=pos().z;"
		"a=0.197;"
		"u_f=0.00787;"
		"n=1e-6;"
		"vel=(2.5*u_f*log((u_f*zp)/(n))+a)*normal();"
     valueExpression "-vel";
    	outlet
       			type            zeroGradient;
	top
			type		symmetry;
	bottom
			type		fixedValue;
			value		uniform (0 0 0);
	walls
			type		symmetry;
"proc.*"
    type            processor;
p/
boundaryField
	inlet
        		type           zeroGradient;
    	outlet
       			type           fixedValue;
			value		uniform 0;
	top
			type		symmetry; 	//zeoGradient;
	bottom
			type		zeroGradient;
	walls
"proc.*"
    type            processor;
k/
internalField   uniform 3.375e-4; //1.5*I_t^2*U_m^2
boundaryField
    inlet
        type            groovyBC;
        variables	(
			"U_m=0.3;"
			"h=0.3;"
			"z0=0.001;"
			"I_t=0.05;"
			"r=pos().z/z0;"
			"I=I_t*((log(h/z0))/(log(pos().z/z0)));"
	valueExpression	"1.5*pow(I,2)*pow(U_m,2)";
    outlet
        type            zeroGradient;
    top
        type		symmetry;			//type           kqRWallFunction;
        						//value          uniform 3.375e-4;
    bottom
    walls
"proc.*"
    type            processor;
epsilon /
internalField   uniform 4.851e-5;
boundaryField
    inlet
        type            fixedValue;
        value           uniform 4.851e-5;
    outlet
        type            zeroGradient;
    top
        type		symmetry;		//type           epsilonWallFunction;
        					//value          uniform 4.851e-5;
    bottom
    walls
"proc.*"
    type            processor;
fvSchemes
ddtSchemes
    default             steadyState;
gradSchemes
    default             Gauss linear;
divSchemes
    default             none;
    div(phi,U)          bounded Gauss upwind;
    div(phi,epsilon)    bounded Gauss upwind;
    div(phi,k)          bounded Gauss upwind;
    div((nuEff*dev2(T(grad(U)))))    Gauss linear;
laplacianSchemes
    default             Gauss linear limited corrected 0.33;
interpolationSchemes
    default             linear;
snGradSchemes
    default             limited corrected 0.33;
fvSolution
solvers
    p
        solver           GAMG;
        tolerance        1e-6;
        relTol           0.1;
        smoother         GaussSeidel;
    U
        solver           smoothSolver;
        tolerance        1e-6;
        relTol           0.1;
        nSweeps          1;
    k
        tolerance        1e-6;
        relTol           0.1;
        nSweeps          1;
    epsilon
        tolerance        1e-6;
        relTol           0.1;
        nSweeps          1;
SIMPLE
    nNonOrthogonalCorrectors 0;
    residualControl
        p               1e-3;
        U               1e-4;
        "(k|epsilon)"   1e-4;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        k               0.7;
        epsilon         0.7;
cache
    grad(U);
Thank you!!!
Kbshariff is offline   Reply With Quote
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 05:37
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
Transition SST model - convergence problem with 2nd order discretization xara FLUENT 4 May 27, 2013 14:16
Convergence in Nat conv problem - simple geometry gradstudent2430 FLUENT 1 April 19, 2012 06:23
transition model convergence problem hammam CFX 3 August 7, 2007 19:33
