interFoam case mesh with baffles crushed
Old   December 16, 2020, 16:08
Default interFoam case mesh with baffles crushed
ves
Veskov Eugene
ves is on a distinguished road
Dear collegues
I solved the problem draining tank with baffles ( baffles installed for prevent liquid rotation ) with interFoam (OpenFOAM 2006). Boundary conditions: Totalpressure at the upper boundary, volume flow rateat the lower boundary, the rest of the boundary is the wall.
The calculation on a mesh without baffles was successful for grids built in ANSYS Fluent Meshing and snappyHexMesh, but for geometry with baffles, a divergent solution is obtained, the velocity increases to 100 m / s, the pressure varies from -5 ^ -10 to 500,000 Pa and he calculation time of one timestep increases dramatically in time for meshes built in ANSYS Fluent Meshing and snappyHexMesh with double-sided baffle surfaces.
Fluent mesh with baffles converted as in Thin Walls Conversion from Fluent Mesh
fluent3DMeshToFoam with baffles as “internal” + createBaffles give bad result too.
snappyHexMesh generate mesh with settings: snappyHexMesh + snappyHexMeshDict->geometry->baffles + createBafflesDict, create double-sided wall (baffle_master and baffle_slave)
Simulation with mesh converted by fluent3DMeshToFoam and baffles as “wall” give mesh with one-sided wall and works good some seconds of physical time, then failed abruptly.
What wrong in this settings? Need I additional work with meshes or it OpenFOAM bug?
ves is offline   Reply With Quote
baffles, fluent, interfoam, mesh, snappyhexmesh
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
GeometricField -> mesh() Function Tobi OpenFOAM Programming & Development 10 November 19, 2020 12:33
dynamic mesh case based of an interFoam case maxonline OpenFOAM Running, Solving & CFD 3 February 21, 2016 15:13
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
