December 15, 2020, 04:58 |
I can't work my case in rhoCentralFoam
Onur Koç
Rep Power: 6 |
Hi,I am new at openFoam.I am trying to work airfoil Naca 0012 tutorial in rhoCentralFoam.It is working in rhoSimpleFoam and rhoPimpleFoam.But why it is not working rhoCentralFoam.And what should I changed to work ? Thank you ?
December 15, 2020, 09:18 |
Herpes Free Engineer
Rep Power: 13 |
To little information on the matter, I would say. Please elaborate your question, if possible. (Might be useful to follow suggestions made in the link "How to create a MWE."), if necessary. Thanks for your understanding.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 15, 2020, 12:01 |
#3 | |
Onur Koç
Rep Power: 6 |
Then,I write rhoCentralFoam it gives ''first error image''. After that I have added the rhoU in fvSolution folder.Then again error ''secon error image''.I have again added div(tauMC) in fvSchemes folder. Then I have type again rhoCentralFoam it gives ''3. error image''. What should I do afterfrom that point ? |
[DesignModeler] DesignModeler Scripting: How to get Full Command Access | ANT | ANSYS Meshing & Geometry | 53 | February 16, 2020 15:13 |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 10:29 |
How to Initialise my LES case using my RANS case is there any utility for it ? | Alhasan | OpenFOAM Running, Solving & CFD | 2 | May 10, 2014 00:14 |
Case (VOF + Solidification&Melting) will not work with Species Transport? ERROR ? | andy.eco | FLUENT | 4 | September 14, 2010 17:27 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 16:31 |
