"decomposePar" not decomposing volumeVectorField located inside user defined folder
Old   December 11, 2020, 02:32
Default "decomposePar" not decomposing volumeVectorField located inside user defined folder
Krishna
kavatar is on a distinguished road
Hello All,
I have to read volumeVectorField variables from a folder named “B”. This folder contains the magnetic field distribution files (i.e. B_0.1, B_0.2, B_0.3………. so on) at different time. I will use different file at different time in the solution.
I want to run the solver in parallel. But, when I use “decomposePar”, the decomposition does not happen to the files located inside the folder “B”.
Can anyone comment on how to decompose the files located inside user defined folders (In my case that folder is “B”)?
kavatar is offline   Reply With Quote
decomposepar, external folder, parallel computaion, volumevectorfield
Regarding DEFINE_VR_RATE and DEFINE_SR_RATE user defined functions in fluent ajithjec FLUENT 0 November 6, 2020 06:36
Assigning source terms in user defined memory which is located at the interface? vidyadhar Fluent UDF and Scheme Programming 0 November 20, 2018 09:06
[General] Paraview User defined view prapanj ParaView 3 January 3, 2014 21:54
user defined turbulence model manuutin STAR-CD 5 October 14, 2009 06:29
UDF - Derivatives for User Defined Memory Variable Sandilya Garimella FLUENT 0 January 14, 2008 11:39
