Proper way to enforce Total Pressure inlet condition in SRFSimpleFoam |
December 3, 2020, 04:48 |
Rep Power: 6 |
Dear FOAMers,
I'm dealing with the case of an impeller for which I want to use SRFSimpleFOAM. I managed to run the case assigning an uniform inlet velocity value, but I would like to enforce a total pressure inlet condition. In order to properly enforce the BC, also an inlet velocity direction must be assigned. The problem is that I'd like to assign the direction in the absolute frame of reference, while SRFSimpleFoam needs as input the Urel file. Is there someone that has experience in such a setup? What is the best solution to enforce a total pressure inlet condition in SRFSimpleFOAM? Thanks in advance |
Acoustic boundary condition with pressure perturbation at inlet | hand90 | CFX | 2 | August 10, 2018 08:36 |
Pressure Inlet Boundary Condition for gas-solid fluidized bed | m.uzair | Fluent Multiphase | 0 | January 18, 2018 07:08 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure | jola | FLUENT | 1 | May 5, 2011 15:33 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
