Wind Flowing from Outlet to Inlet
Old   December 2, 2020, 11:17
Post Wind Flowing from Outlet to Inlet
Anon
CfdUser5855 is on a distinguished road
I am trying to simulate windflow over a simple terrain using pimpleFoam to see if my case is set up correctly before I run it over a high resolution mesh, however the flow as seen in the image attached is coming from the outlet to the inlet. It is meant to be flowing from right to left as seen in the image attached
It is meant to be coming in at an slight angle, which is why my flowDir is written like that in the ABL Conditions file below
I have tried reversing the flowdir and removing the negative signs, however the windflow keeps coming through the outlet face rather than the inlet.
If anyone could advise, that would be greatly appreciated (I have checked my mesh and the outlet/inlet are definitely defined for the correct faces)
U File:
#include "include/initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
inlet
type atmBoundaryLayerInletVelocity;
#include "include/ABLConditions"
outlet
type inletOutlet;
inletValue uniform (0 0 0);
value $internalField;
top
type zeroGradient;
DuneField
type uniformFixedValue;
value uniform (0 0 0);
uniformValue constant (0 0 0);
sides
type slip;
ABL Conditions File:
Uref 13.36;
Zref 5;
zDir (0 0 1);
flowDir (-0.997564 -0.0697565 0);
z0 uniform 0.03;
zGround uniform 0;
CfdUser5855 is offline   Reply With Quote
cfd, flow angle, pimplefoam
wind inlet with angle fr_epfl OpenFOAM 2 November 9, 2020 09:32
Pressure Boundary Inlet and Outlet AS_Aero CFX 5 March 28, 2018 11:46
Total Pressure Drop at inlet and outlet AS_Aero Main CFD Forum 10 September 8, 2017 05:54
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? p07ip705 Main CFD Forum 3 August 3, 2012 06:53
steam flow in a pipe driven by a pressure gradient between inlet and outlet SalvoCalvo COMSOL 0 March 11, 2010 07:52
