[Immersed Boundary Method] Error with turbulence model |
Thomas Shi
Rep Power: 8 ![]() |
Hello everyone, I am currently using the immersed boundary solver interIbFoam with Foam-extend 4.0 to solve a question with RANS turbulence model. I have made the case according to tutorials and started the simulation. Then it comes out an error with boundary conditions of turbulence coeffeciants. The error message is showing below.
--> FOAM FATAL ERROR: gradientInternalCoeffs cannot be called for a genericFvPatchField (actual type immersedBoundaryEpsilonWallFunction) on patch ibCylinder of field epsilon in file "/mnt/g/foam/thomaschi-4.0/run/cylBumpInterIbFoam/0/epsilon" You are probably trying to solve for a field with a generic boundary condition. From function genericFvPatchField<Type>::gradientInternalCoeffs() const in file fields/fvPatchFields/basic/generic/genericFvPatchField.C at line 832. FOAM exiting |
Tamas Egeresi
Rep Power: 11 ![]() |
Hi!
The problem relies on your boundary conditions. There is a boundary which is not consistent, so the simulation is under constrained.
Tamas Egeresi Senior Hydraulics Engineer CFD Egeresi www.cfdegeresi.freecluster.eu |
boundary condition, foam-extend 4.0, immersed boundary method, turbuelence model |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 19:42 |
