Disperse flow - adding Particles
Old   November 24, 2020, 11:04
Lightbulb Disperse flow - adding Particles
Particles
Particles is on a distinguished road
Dear all,
I was wondering how exactly the injection of particles in a fluid works. So if you have a flow from inlet to outlet, and you add Particles at the inlet to track them. How does the solver (MPPICFoam) treat the circumstances of the added mass in the fluid? Is the fluid which was at the area of the particle deleted? How many partcles (amount and mass) can be added (compared to the fluid) without any troubles?
Are there some usual problems with it?
Best!
Particles is offline   Reply With Quote
Old   November 26, 2020, 05:18
oswald is on a distinguished road
I think that the MPPIC solver does account for particle volume fraction in the NS-equations by using the carrier fluid phase fraction as a factor. So yes, the fluid is somehow deleted. The maximum amount of particles is determined by the packing model you use. The dev-version for example provides explicit and implicit packing models.
I suggest reading the original paper by O'Rourke:
https://doi.org/10.1016/0301-9322(95)00072-0
oswald is offline   Reply With Quote
added mass, dispersed fluid, injectionrate
Flow Simulation in Drain Pipe with solid Particles armani Fluent Multiphase 4 November 6, 2018 05:34
Number of particles based on mass flow rate in DPM Saptarshi Fluent Multiphase 1 May 24, 2018 09:49
Particles in the flow nissen21 Fluent Multiphase 5 May 21, 2014 20:21
Interpolate particles together with flow asal FLUENT 0 March 30, 2014 15:22
spherical particles in a flow stream Adolfo Menendez Main CFD Forum 3 September 3, 1998 16:13
