Error: "Source airToporous defined for field h but never used"
Old   November 22, 2020, 12:00
Question Error: "Source airToporous defined for field h but never used"
Utkan Erdem
Utkan is on a distinguished road
I am a newbie in OpenFOAM and I desperately need any type of help or guidance in my situation. I want to simulate the forced cooling of a radiator with air by a fan. I am working with the heatExchanger case under chtMultiRegionFoam. However, the amount of fin/capillary details of this radiator makes it impossible to mesh with a commercial meshing tool. Hence, I'm going for the porosity approach. Water is considered a porous fluid of which the porous parameters are given in the fvOptions. I will include fvOptions of both regions below. The momentum source term due to the porosity blockage is I think already being added correctly, but from what I understood, I have to find a way to add the energy source term to get rid of the warning. But I don't know how to do that. I would really appreciate any help overcoming this error. Thank you in advance.
This is the error that I get, when I try to solve the case
Solving for fluid region air
--> FOAM Warning :
    From function virtual void Foam::fv::option::checkApplied() const
    in file cfdTools/general/fvOptions/fvOption.C at line 125
--> FOAM Warning :
DILUPBiCGStab:  Solving for Ux, Initial residual = 0.474622, Final residual = 0.00170632, No Iterations 1
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.403169, Final residual = 0.00159073, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 0.573588, Final residual = 0.00181622, No Iterations 1
--> FOAM Warning :
--> FOAM Warning :
DILUPBiCGStab:  Solving for e, Initial residual = 0.00898525, Final residual = 5.40341e-05, No Iterations 1
Min/max T:292.92 325.612
--> FOAM Warning :
GAMG:  Solving for p_rgh, Initial residual = 0.441588, Final residual = 0.00311991, No Iterations 12
time step continuity errors : sum local = 0.000507967, global = 3.8117e-05, cumulative = 3.8117e-05
--> FOAM Warning :
--> FOAM Warning :
DILUPBiCGStab:  Solving for epsilon, Initial residual = 0.0690558, Final residual = 0.000399087, No Iterations 1
--> FOAM Warning :
--> FOAM Warning :
the fvOptions for both regions is as follows;
For air region;
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  8
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      fvOptions;
airToporous
    type            constantHeatTransfer;
    interpolationMethod cellVolumeWeight;
    nbrRegionName   porous;
    master          false;
    nbrModel        porousToair;
    fields          (h);
    semiImplicit    no;
porosityBlockage
    type            interRegionExplicitPorositySource;
    interRegionExplicitPorositySourceCoeffs
        type            DarcyForchheimer;
        d   (-1000 -1000 1e4);
        f   (0 0 0);
        coordinateSystem
            type    cartesian;
            origin  (0 0 0);
            coordinateRotation
                type    axesRotation;
                e1      (0 1 0);
                e2      (0 0 1);
For the porous region;
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvOptions;
porousToair
    nbrRegionName   air;
    master          true;
    nbrModel        airToporous;
    fields          (e);
    semiImplicit    no;
Utkan is offline   Reply With Quote
Old   March 31, 2022, 15:51
Raphael Santos
Raphael_Santos is on a distinguished road
Hello Utkan,
have you find a solution to that issue?
Cheers,
Raphael_Santos is offline   Reply With Quote
Old   April 6, 2022, 09:23
Lukas
Pappelau is on a distinguished road
he defined energy as h in fvoptions but is using in the theromprops the formulation with epsilon this visible in the solver log: solving for epsilon .... this cant work out
Pappelau is offline   Reply With Quote
chtmultiregionfoam, energy source term, fvoptions, heat exchanger two fluids, porosity; fvoptions
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 14 February 12, 2017 14:44
UDF link fortran source yorelchr Fluent UDF and Scheme Programming 0 February 7, 2013 04:44
using METIS functions in fortran dokeun Main CFD Forum 7 January 29, 2013 05:06
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
