Arijit Saha
Rep Power: 7 ![]() |
Hello Foamers,
I am using Channel 395 case in Openfoam and sampling the time series data at a midplane surface which later I'm interested in using as an inlet to another channel flow. Also using some other Inflow turbulence generation method like KSEC where I m trying to keep the mean velocity function and standard deviation function similar to the Channel395 case. So, in this regard does anyone have any idea like how to figure out the functions from channel395? |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 01:27 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
