compressibleInterFoam blows up part way through simulation |
November 20, 2020, 13:55 |
Rep Power: 13 |
I'm running a transient two-phase flow case with compressibleInterFoam. I have a slug of water in a pipe being accelerated by air at high pressure. The simulation blows up after about 200 iterations with a floating point exception. I am wondering if anyone has any insight into what may be crashing my simulation.
The output just prior to the crash is as follows: Code:
Courant Number mean: 0.17185088 max: 0.50333978 Interface Courant Number mean: 0.00033905591 max: 0.32202209 deltaT = 4.1666667e-06 Time = 0.01817083333 PIMPLE: iteration 1 MULES: Solving for alpha.water Phase-1 volume fraction = 0.040471844 Min(alpha.water) = -0.00010445997 Max(alpha.water) = 1.0000003 MULES: Solving for alpha.water Phase-1 volume fraction = 0.04047171 Min(alpha.water) = -0.00010295604 Max(alpha.water) = 1.0000003 DILUPBiCGStab: Solving for T, Initial residual = 9.7342668e-05, Final residual = 1.0175892e-09, No Iterations 1 Code:
MPT ERROR: Rank 94(g:94) received signal SIGFPE(8). Process ID: 201260, Host: r3i3n18, Program: /p/app/openfoam/OpenFOAM-v1906/platforms/linux64GccDPInt64Opt/bin/compressibleInterFoam MPT Version: HPE MPT 2.17 11/30/17 05:59:14 I have also attached the volume fraction and p_rgh contours just prior to the crash. The p_rgh contours look like there's some numerical artifacts on the left edge of the liquid slug (where it is pushing against the air ahead of it). I appreciate any suggestions on how to fix this simulation. |
November 21, 2020, 11:33 |
Rep Power: 13 |
The problem has been fixed by increasing the number of PIMPLE corrector steps (found in the system/fvSolution file). In my case, this was set to 2 correctors, which is probably insufficient to achieve convergence when large pressure gradients begin to form in the solution. Increasing the number of correctors to 10-20 has allowed the solution to run to completion.
Error Messages: Self intersecting faces, Solid Part is not closed, Floating point. | bigtoasty | STAR-CCM+ | 1 | March 4, 2016 05:05 |
Selecting the faces of part body after Enclosure and boolean operations | Amar21 | FLUENT | 6 | November 19, 2015 10:23 |
Structural analysis- bosy surface part from the solid part | andreina | Structural Mechanics | 0 | October 12, 2015 09:56 |
Integration of part of the simulation domain | Edwon | OpenFOAM Programming & Development | 6 | September 17, 2015 05:20 |
Reaction Force calculation in solid part in 2-way FSI simulation with CFX | esbolico | ANSYS | 0 | September 17, 2013 08:54 |
