Sliding of bubble on heated surface in nucleate boiling
Old   November 20, 2020, 07:38
Default Sliding of bubble on heated surface in nucleate boiling
M Naarendharan
Naaren is on a distinguished road
I am working with the solver interThermalPhaseChangeFoam (https://www.sciencedirect.com/scienc...52711016300309) to simulate the growth of single bubble. When I simulate the bubble in a three dimensional domain (Cube, with bubble at center) the bubble starts to slide on the surface. It be very much helpful if someone can suggest a solution to debug this issue.
Thank you,
M Naarendharan
Naaren is offline   Reply With Quote
Old   November 25, 2020, 23:26
M Naarendharan
I am still facing the issue. Any suggestions would be very much appreciated.
Thank you,
M Naarendharan
Old   November 27, 2020, 00:55
Default More description of the probem
M Naarendharan
My study is growth of a single bubble in saturated liquid inside a cubical domain with the bottom face having a constant temperature above the saturation temperature.
What is expected: The bubble is set at the base and is expected to leave the base after growing in size.
Problem: The bubble grows in size and starts moving on the heated plane.
Image files of the problem: https://drive.google.com/drive/folde...zz?usp=sharing
Setfields, blockMesh, Boundary Conditions: https://drive.google.com/drive/folde...7y?usp=sharing
Thanking you,
M Naarendharan
#bubble, #nucleateboiling, #openfoam
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? EternalSeekerX SU2 3 October 9, 2020 19:28
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 12:42
2D ship motion in cfx with sliding mesh: free surface displace with sliding interface esmail CFX 3 July 4, 2015 09:46
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
