Cylinder with potentialFoam fails (library error) |
Thomas
Rep Power: 0 ![]() |
I am using OpenFOAM v2006 under OpenSUSE 15.1. I am able to run examples from the tutorials provided in the OpenFOAM installation. E.g. airfoild2d with simplefoam. Installation seems to be ok. Now I try to run a very basic case which is also provided in the tutorials. basic/potentialFoam/cylinder. It fails within the solver step. I am getting an error in the log for potentialFoam. I did not change anything in the scripts and dictionaries from the tutorial. But it fails if I run it with './Allrun'. ... Using dynamicCode for functionObject error at line 52 in ... Attached is the log file and the controlDict. I do not have any idea what I am doing wrong. Best regards, Thomas Last edited by ts66; November 25, 2020 at 13:42. |
Compile problem | ivanyao | OpenFOAM Running, Solving & CFD | 1 | October 12, 2012 09:31 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 09:30 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
