November 16, 2020, 13:40 |
Linking Two Patches
Rep Power: 6 |
Hi all,
I have a problem where I have two plates stacked on top of each other. I want to values of the top plates bottom patch Temperature to pass along the information to the bottom plates top patch. I have two questions: 1. Is this possible or is there a better way of achieving this? 2. How can I achieve this if it is possible? |
November 16, 2020, 13:45 |
Rep Power: 15 |
In short, yes. You will want to use coupled/mapped patches. Guessing that you are going to want to use the chtMultiRegionFoam solver -- those tutorials should be good references.
Caelan |
openfoam, patch, patch gradient |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
Problem using AMI | vinz | OpenFOAM Running, Solving & CFD | 298 | November 13, 2023 09:19 |
[snappyHexMesh] snappyHexMesh error "Cannot determine normal vector from patches." | lethu | OpenFOAM Meshing & Mesh Conversion | 1 | June 3, 2020 08:49 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 09:00 |
OpenFOAM with Cygwin | kitchener | OpenFOAM Installation | 6 | April 25, 2006 00:09 |
