Multple FvOptions in OpenFOAM
Old   November 16, 2020, 04:50
Default Multple FvOptions in OpenFOAM
mohammad
mostanad is on a distinguished road
Hello my friends,
I am using fvOption tool to force a desired mean velocity in my periodic domain. The domain needs to mimic an unbounded box, so it should have zero mean velocity at three directions. To this end, I am forcing the zero Ubar through meanVelocityForce in my fvOption file. However, the fvOption cannot get the exactly zero value. A solution can be a very small value like
Ubar= (1e-7 1e-7 1e-7)
So do you think whether it is a good solution? Does it force zero mean velocity in my domain? How about using multiple fvOption sources like:
Ubar=(1e-7 0 0)
Ubar=(0 1e-7 0)
Ubar=(0 0 1e-7)
Is this possible in OF to use multiple meanVelocityForce sources?
Thank you for your help.
Mo
mostanad is offline   Reply With Quote
Old   November 17, 2020, 02:23
mohammad
Is this equivalent to these fvOption source terms?
momentumSource1
    type            meanVelocityForce;
    active          on;
    selectionMode   all;
        fields  (U);
        Ubar        (0 0 0.0000001);
momentumSource2
    active          on;
    selectionMode   all;
        fields  (U);
        Ubar        (0 0.0000001 0);
momentumSource3
    active          on;
    selectionMode   all;
        fields  (U);
        Ubar        ( 0.0000001 0 0);
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin CFDFoundation OpenFOAM Announcements from Other Sources 0 January 4, 2017 07:15
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 08:18
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
