Mass Transfer Using chtMultiRegionFoam.
Old   November 12, 2020, 21:04
Default Mass Transfer Using chtMultiRegionFoam.
Enternald is on a distinguished road
Hi all,
I am trying to use chtMultiRegionFoam to solve the mass transfer (approximated as Fick's Law) through a solid. So the geometry that I have setup looks like this.
oxygen (fluid) (10cm tall)
solid membrane (solid) (1mm tall)
'vacuum' (approximated by low oxygen region) (fluid) (1cm tall)
I believe I need an two internal boundary layers on the membrane, one at the concentration of oxygen in the top and one initially at the low-zero concentration of oxygen at the bottom (outlet) of the solid material.
Does anyone have any experience or examples of using this chtMultiRegionFoam being used for a mass transfer problem? I am assuming isothermal as well.
Any help or direction would be much appreciated! Thank you.
Enternald is offline   Reply With Quote
chtmultiregionfoam, isothermal, openfoam
Mass transfer between air and water aminhgn Fluent UDF and Scheme Programming 4 October 18, 2020 12:54
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
How to calculate Volumetric Mass transfer coefficient using CFX? tuks_123 CFX 2 July 22, 2010 02:15
