Simulation of aerator in a large tank
Old   November 6, 2020, 11:48
Default Simulation of aerator in a large tank
Farzad Faraji
farzadmech is on a distinguished road
Dear Friends
I am simulating aerator in a large tank. Since I am simulating both aerator and large tank at the same time, I want to use the same mesh size all over the domain to avoid different timescales(eg if I use smaller mesh for aerator, my time step will be much smaller). To do so, I have used fvOptions to generate a source of momentum to push the water out of the channels and also suck the water to the aerator(You can see it as a red cylindrical momentum source).
I have done all aforementioned things using pimplefoam(I am just working with water instead of water and air mixture), but my simulation is instable. Now, I have two questions;
1- How can make it stable?
2- Is there any other way I can simulate the outlet of the channels without considering the aerator chamber? If so, what is happening to continuity equation? since mass increases inside the domain without any outlet.
3- Do you have any other suggestion for me?
Thanks,
Farzad
farzadmech is offline   Reply With Quote
Old   November 6, 2020, 12:22
Default Question about complex geometries using toposSetDict
Farzad Faraji
Hello again
How can I generate complex geometries using toposSetDict? Is it feasible or not?
I want to put my momentum source inside the channels of aerators, but first I have to define that region inside the channels using toposSetDict?
Thanks
Farzad
aerator, fvoptions, instable, large tank, openfoam
Solid object falling in water tank simulation cassini83 CFX 3 August 9, 2021 18:05
Tank refuelling simulation Bisht STAR-CCM+ 4 July 30, 2015 12:02
Which solver is appropriate for microbubble flow simulation in a tank ? waku2005 OpenFOAM Running, Solving & CFD 0 June 23, 2015 23:20
Simulation of Wave generation in a tank Nidhin R Fluent UDF and Scheme Programming 0 January 1, 2015 06:27
[ICEM] Mesh strategy large tank DoubleG ANSYS Meshing & Geometry 2 January 10, 2013 11:15
