David
Rep Power: 5 ![]() |
Hi all,
While using buoyantSimpleFoam in an backwards u like shape i am getting a strange pressure field and no outflow. I guess it must be becouse of the boundary conditions... the boundary conditions are: __________U ________P_________ ____p_rgh _________T Inlet ______fV______ ___calculated ___fFPresuure_____ fV __________uni(-0.8 0 0) _____________gradient 0 _____uni 343.15 _________________________________value uni 1e5 walls _______no slip _____calculated ___fFPresure _______zG __________________________________gradient 0 _________________________________value uni 1e5 0utlet ______inletOutlet__ _calculated____ fixedValue_____ inletOutlet ________inletValue uni (0 0 0)_ _________uniform 1e5_____iV uni 343.15 __________value uni (0 0 0) __________________________v uni 343.15 Im greatfull for any help. |
Kira
Rep Power: 8 ![]() |
Hello David,
Could you please clarify what you are asking? Are you asking why the high pressure is occurring, or what boundary condition is causing this? |
David
Hi Kira,
I am asking both, and most of all, how to fix it. Thanks, David |
David
I found a solution, in witchthe flow was perfect eventaugh ithink there would be a nicer solution. I put the gravity to 0. |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 01:33 |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
What is difference between static pressure and gauge pressure? | aja1345 | FLUENT | 1 | July 20, 2018 20:05 |
Getting divergence while increasing the back pressure at pressure outlet | greenfields15 | FLUENT | 0 | March 18, 2018 23:39 |
Strange oscillatory pressure in periodic incompressible flow | EmiS | FLUENT | 0 | February 6, 2018 18:03 |
