Difference cl/cd result between simpleFoam and pimpleFoam |
TWB
Rep Power: 19 ![]() |
I'm trying to run a simple case of flow past 2D s1020 airfoil at Re = 100. I have used an O grid, running at 200x50, 400x97 and 800x200. At 1st, I used simpleFoam and the ans between the 3 differs by a bit. At aoa = 0deg, cl ~ 0.04, cd ~ 0.4 Next, I rerun the cases using pimpleFoam. At aoa = 0deg, cl ~ 0.2, cd ~ 4, altohugh it still very slowly declining. But the difference is still too much. The files are almost the same so which is this so? Any hint? Re 100 and AOA ~ 0, shouldnt the flow be steady? Thanks |
Getting low cl for wing in pimpleFoam and oscillating cl in simpleFoam | quarkz | OpenFOAM Running, Solving & CFD | 0 | August 15, 2020 03:48 |
Start pimplefoam with simplefoam results | pascalCFD | OpenFOAM Running, Solving & CFD | 0 | April 1, 2020 11:48 |
Strange result for 2D foil (simpleFoam & pimpleFoam) | wyj216 | OpenFOAM Running, Solving & CFD | 2 | October 1, 2019 03:13 |
Starting pimpleFoam computation from simpleFoam result | vinz | OpenFOAM Running, Solving & CFD | 9 | March 17, 2014 12:35 |
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H | uli | OpenFOAM Programming & Development | 7 | January 26, 2013 15:01 |
