Negative initial temperatures using buoyantSimpleFoam
Old   November 4, 2020, 11:03
Default Negative initial temperatures using buoyantSimpleFoam
David
CFDave_ is on a distinguished road
I'm getting a Fatal error using buoyantSimpleFoam, with negative initial values. I first used a simple geometry were the Simulation ran fine. After extending the geometry to an S like shape with a longer inlet and outlet I am suddenly getting negative temperatures and an unusual pressure field.
I have atechd a file with the boundary conditions and a plot of the pressure Field.
I am guessing the problems are the boundary conditions,
i would be greatfull for any help.
CFDave_ is offline   Reply With Quote
Old   November 4, 2020, 11:21
Bineet Mehra
bineet_aero is on a distinguished road
check your mesh !!! i faced the same error for almost similar problem, got rid of the error by improving my mesh without making any other change
bineet_aero is offline   Reply With Quote
Old   November 4, 2020, 12:02
David
thanks for the quick reply, I already checked, I also get a strange pressure field and no flow with a perfect mesh.
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
Segmentation fault when using reactingFOAM for Fluids Tommy Floessner OpenFOAM Running, Solving & CFD 4 April 22, 2018 13:30
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
