SimpleFoam: Weird low velocity region/bar at leading edg |
Kyfrankie
Rep Power: 5 ![]() |
The case is ran with SimpleFOAM using kOmegaSST turbulence model at RE=50000, free stream velocity of 4.8m/s. The solution reached a steady "converged" stage but the residual of p fail to drops below 1e-3, others residuals are okay though. However, when viewing the U in paraView, there's two weird low velocity region at the leading edge. I am puzzled about what is going on
Troy Snyder
Rep Power: 19 ![]() |
The "lines" appear to coincide to the transitions in surface mesh density. I suspect the low velocities are of numerical origin.
Kyfrankie
Thanks a lot for your reply. I have made the refinement level to the same (6,6) and the "line" seems to be less aggressive but still appear. In addition, if the force coefficient converged to a stable value but the residuals fail to drop below 1e-4. Is it still considered converged? Any advice to improve convergence? Thanks in advance!
#4 | |
Troy Snyder
Michael Alletto
Rep Power: 16 ![]() |
There may be some reciculation regions on the right edge of the airfoil which explains the high pressure residuals.
Regarding the low velocity close to the leading edge did you check if you can expect a laminar recirculation bubble. Michael |
Kyfrankie
I believe the "line" may be caused by an issue in the STL file. Also, I found that by setting the refinement of the Wing to be uniform (6 6) instead of (6 7) helps the convergence after adding a absolute layer near the wing wall.
Michael Alletto
The stl seams to be not smooth. So probably you have to fix this first. Do you have wall layers? What kind of boundary conditions are you using
Weird velocity results for low mach number combustion | Rafael Meier | OpenFOAM Running, Solving & CFD | 0 | June 8, 2018 11:36 |
Velocity in Porous medium : HELP! HELP! HELP! | Kali Sanjay | Phoenics | 0 | November 6, 2006 06:10 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 02:13 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
