How to assign dynamicMeshDict for 1 full body rotation + 2 ailerons deflection |
October 29, 2020, 04:21 |
TWB
Rep Power: 19 |
I have 3 bodies - 1 wing + 1 left aileron + 1 right aileron. I need to simulate these 2 motions together: 1. entire full body roll motion - so all the 3 bodies will rotate, no mesh deformation 2. left aileron deflect upwards at constant rotation rate of 5deg/s, mesh will deform 3. right aileron deflect downwards at constant rotation rate of 5deg/s, mesh will deform So can these be done in OF easily? I can rotate entire body using this in dynamicMeshDict: dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libfvMotionSolvers.so"); motionSolver solidBody; cellZone none; solidBodyMotionFunction rotatingMotion; rotatingMotionCoeffs { origin (0.1 0. 0.); omega 0.45378560551852569000015959980704; //units of rad/s axis (1 0 0); } I can also deflect a single aileron using this in 0/pointDisplacement: wing_aileron_left { type angularOscillatingDisplacement; value uniform (0 0 0); axis (-0.309456346 -0.051111141 -0.949539057); origin (0.83342853 0.070126234 1.6370375); angle0 0; amplitude 0.13439035240356337742312418917362; //units of rad omega 6.283185307179586476925286766559; //units of rad/s } However, combining them doesn't work. Also, is there a simple rotation motion to rotate the aileron? I can only use angularOscillatingDisplacement, which is not exactly what I want. Can I use dynamicMultiMotionSolverFvMesh? Do I need to define the cellZone? Thanks. |
October 31, 2020, 04:26 |
Rep Power: 8 |
I think the relativeMotion tutorial does something similar to what you're after.
About the rotation of the aileron, I suggest modifying the angularOscillatingDisplacment class so that it reads time-value pairs from a file. It's pretty simple to do, just add a member to the class of type TimeFunction1. This way you can specify any kind of rotation you like. |
October 31, 2020, 05:10 |
TWB
Rep Power: 19 |
Hi Tecmul,
Thanks for the suggestions. I will try the modification, although my C++ skill is quite poor. As for the relativeMotion, it's a bit different and I've been trying to modify it but so far I've not been successful. Will keep trying. |
Fluid Domain moving with Rigid body | Lloyd Sullivan | CFX | 3 | August 17, 2018 10:58 |
UDF for solid body rotation | araz | Fluent UDF and Scheme Programming | 1 | January 13, 2016 03:46 |
Rigid body rotation NOT through the CG? | Joe | FLUENT | 6 | May 28, 2010 12:03 |
How can I view the rotation within a full rotation phase | undeadking | CFX | 1 | February 18, 2010 18:06 |
Rotation of bluff body (fluid-structure interactio | James | CFX | 0 | February 25, 2005 06:38 |
