October 26, 2020, 09:17 |
Weird velocity fluctuations
Rep Power: 8 |
Hi foamers,
I have notices weird velocity fluctuations in my underexpanded jet. I have attached the velocity field and density field as images. Those fluctuations occur only when I use second order schemes. I am using the solver rhoCentralFoam (openfoam4). I have tried reducing the Co-Number to 0.1 and the limiter schemes MinMod, vanAlbada and vanLeer. Only upwind seems to smear them out. I use the kOmegaSST turbulence model. Does anyone ever had such an issue? I would be greatful for any advice. Kind regards, shock77 |
October 26, 2020, 22:45 |
#2 | |
Illia
Rep Power: 6 |
Hi I've had the same problem. I think they call it a chess board issue. Solutions that helped me: 1) I've added 0.1 m/s velocity field. 2) I started to use SimpleFoam instead of Pimple Would be great to see if there are anything else that might help Cheers |
October 27, 2020, 10:06 |
Rep Power: 8 |
thank you very much for your hints! I am interested in the dynamic behavior, so rhoSimpleFoam is not an option for me. I have already initiated my field with (1 0 0), becazse I knew it could lead to some problems initiating with (0 0 0). Since the flow is the 3D, I have tried (0.1 0.1 0.01) and... it worked! Those weird fluctuations disappeared! Thank you very much, that helped me a lot! Kind regards, shock77 |
November 12, 2020, 04:39 |
Rep Power: 8 |
They actually reappeared with a finer mesh.
Do you have an advice to solve that issue? I also tried reducing the timestep (Co= 0.2 and 0.1) but it didnt help. |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 459 | September 12, 2024 12:47 |
Velocity Sampling in parallel simulation | Torii_Nagi | Fluent UDF and Scheme Programming | 1 | July 20, 2020 02:29 |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 12:19 |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Weird transverse velocity in a channel | dancoz87 | OpenFOAM Running, Solving & CFD | 0 | April 7, 2014 18:16 |
