Boundary Conditions k-omega-SST with slip walls |
October 23, 2020, 08:14 |
Rep Power: 8 |
I am running a simulation of a highly underexpanded jet. The simulation runs stable when laminar. If I try to use a turbulence model, the simulation crashes. I have tracked the values for k, omega and nut and I think the simulation crashes because I get very high turbulent viscosities ( up to 130). The strange thing is, that the high viscosities are in areas far away from the jet and near the walls. Thats why I think wrong boundary conditions lead to those artefacts. My walls are slip, because I am not interested in the boundary layer, which is very small and would need much effort to resolve. I am interested in the shear layer of the underexpanded jet. My boundary conditions for k, omega, nut and alphat are: k
October 23, 2020, 08:43 |
#2 | |
Santiago Lopez Castano
Rep Power: 16 |
Well, if you have a slip wall, then you don't have momentum gradients of any kind there, hence, turbulence can only be transported but not produced. Furthermore, the no-penetration condition doesn't allow for k/omega to be convected out of the domain. This only leaves diffusive transport which, by setting free-Slip, you're also killing off... You have a local variation of k/omega not being balanced locally by any other operator... |
October 23, 2020, 10:39 |
Rep Power: 8 |
Hi Santiago,
so basically what I am doing is to accumulate my turbulent quantities at the boundaries, right? So in order to stabilize my simulation I should zeroGradient at the walls for k, omega, nut and alphat? |
October 23, 2020, 11:05 |
#4 | |
Rep Power: 16 |
Depending on the quality of your grid, you might need to clip the viscosity as well, to, say, 5000 times the molecular viscosity... |
October 23, 2020, 11:59 |
Rep Power: 8 |
So you suggest a fixedValue = 0 for k and a fixedValue = x for omega. I have read this in many cases, that this has been done.
But what do you mean with clipping the viscosity? What boundary condition would you suggest for nut? |
October 23, 2020, 12:17 |
#6 | |
Rep Power: 16 |
nut should't have boundary conditions, as you are not solving a PDE for it in this case. Perhaps you need to impose wall functions on the walls. |
October 23, 2020, 17:57 |
Rep Power: 8 |
I am applying Boundary Conditions on nut to get the field for postProcessing.
I have tried using wallfunctions aswell, but nut still rises above 130. I have tried wallfunctions + slip and wallfunctions + noslip. Both with the same result. |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 18:30 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
