rhoSimpleFoam Help
Old   October 21, 2020, 05:16
Default rhoSimpleFoam Help
maike151 is on a distinguished road
Hello everyone,
I am trying to do a rather simple test case where a hot air stream in a pipe like shape is at some point mixed with a colder air stream and I want to find out the temperature at the outlet.
The Mach numbers are very small (<= 0.01), thus I probably would not need to use a compressible solver. However, I need the temperature field and I didn't find such an incompressible solver.
My problem is that the simulation does not converge. I tried a lot of relaxation factors and boundary condition combinations but nothing seems to help. I also tried to start with very low relaxation factors and increased them after about 100.000 iterations each, still no convergence.
Maybe somebody has an idea what I'm doing wrong.
You can find the case here: https://www.dropbox.com/sh/xlpwf1had...z_CzdpB6a?dl=0
Thank you
Maike
maike151 is offline   Reply With Quote
Old   October 22, 2020, 10:04
If anybody wondered.. I fixed the problem by simulating with turbulence (RAS - kEpsilon) and starting off with very low relaxation factors (0.01) for every variable except U (0.8).
heat transfer, hot air, multiple inlets, rhosimplefoam, thermophysical model
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 07:54
rhoSimpleFoam doubts on BC and fvSchemes (external aero) giovanni.medici OpenFOAM Running, Solving & CFD 3 October 27, 2021 06:06
rhoSimpleFoam angledDuctExplicitFixedCoeff tutorial fails in parallel donQi OpenFOAM Running, Solving & CFD 1 February 22, 2016 20:47
rhoSimpleFoam. patchField error. 123 OpenFOAM Running, Solving & CFD 4 June 6, 2014 16:22
Question about rhoSimpleFoam "if (transonic)" universez OpenFOAM 4 April 17, 2010 11:21
