Heat and mass transfer using multiphaseEulerFoam solver in OF-8
Old   October 13, 2020, 15:08
Default Heat and mass transfer using multiphaseEulerFoam solver in OF-8
Viraj Belekar
viraj20feb is on a distinguished road
Hello everyone,
I have three phases solid, liquid, and gas. I want to simulate heat transfer between all three phases, and mass transfer between liquid and gas. I am using multiphaseEulerFoam solver in OF-8. My simulation breaks down immediately in the first time step and gives me the following error:
#0 Foam::error:rintStack(Foam::Ostream&) at ~/OpenFOAM-8/OpenFOAM-8/src/OSspecific/POSIX/printStack.C:218
#1 Foam::sigFpe::sigHandler(int) at ~/OpenFOAM-8/OpenFOAM-8/src/OSspecific/POSIX/signals/sigFpe.C:104
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ~/OpenFOAM-8/OpenFOAM-8/src/OpenFOAM/fields/Fields/scalarField/scalarField.C:114 (discriminator 2)
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/viraj/OpenFOAM-8/OpenFOAM-8/platforms/linux64GccDPInt32Debug/bin/multiphaseEulerFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ~/OpenFOAM-8/OpenFOAM-8/src/OpenFOAM/lnInclude/GeometricScalarField.C:107 (discriminator 8)
#6 Foam:hasePair::Pr() const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/phaseSystems/phasePair/phasePair/phasePair.C:135
#7 Foam::heatTransferModels::RanzMarshall::K(double) const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/interfacialModels/heatTransferModels/RanzMarshall/RanzMarshall.C:65
#8 Foam::heatTransferModel::K() const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/interfacialModels/heatTransferModels/heatTransferModel/heatTransferModel.C:78
#9 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::BlendedInterfacialModel<Foam::heatTransferMo del>::evaluate<double, Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > (Foam::heatTransferModel::*)() const, Foam::word const&, Foam::dimensionSet const&, bool) const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/multiphaseSystems/../../phaseSystems/lnInclude/BlendedInterfacialModel.C:175 (discriminator 6)
#10 Foam::BlendedInterfacialModel<Foam::heatTransferMo del>::K() const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/multiphaseSystems/../../phaseSystems/lnInclude/BlendedInterfacialModel.C:397
#11 Foam::TwoResistanceHeatTransferPhaseSystem<Foam::M omentumTransferPhaseSystem<Foam:haseSystem> >::heatTransfer() const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/multiphaseSystems/../../phaseSystems/lnInclude/TwoResistanceHeatTransferPhaseSystem.C:462 (discriminator 3)
#12 Foam::PhaseTransferPhaseSystem<Foam::TwoResistance HeatTransferPhaseSystem<Foam::MomentumTransferPhas eSystem<Foam:haseSystem> > >::heatTransfer() const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/multiphaseSystems/../../phaseSystems/lnInclude/PhaseTransferPhaseSystem.C:332
#13 Foam::InterfaceCompositionPhaseChangePhaseSystem<F oam::PhaseTransferPhaseSystem<Foam::TwoResistanceH eatTransferPhaseSystem<Foam::MomentumTransferPhase System<Foam:haseSystem> > > >::heatTransfer() const at ~/OpenFOAM-8/OpenFOAM-8/applications/solvers/multiphase/multiphaseEulerFoam/multiphaseEulerFoam/multiphaseSystems/../../phaseSystems/lnInclude/InterfaceCompositionPhaseChangePhaseSystem.C:455
#14 ? in "/home/viraj/OpenFOAM-8/OpenFOAM-8/platforms/linux64GccDPInt32Debug/bin/multiphaseEulerFoam"
#15 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#16 ? in "/home/viraj/OpenFOAM-8/OpenFOAM-8/platforms/linux64GccDPInt32Debug/bin/multiphaseEulerFoam"
I believe that the error is in the phaseProperties file (attached). Can anyone please guide me in the right direction in order to get rid of this error?
Thank you!
viraj20feb is offline   Reply With Quote
Old   November 9, 2020, 00:48
Sumit Peh
Jamessmp23 is on a distinguished road
Have you solved your case ?
How do you apply mass transfer equation in your case ? I'm trying to apply my mass transfer equation in K modelled but I found only a way to change mass transfer in empirical model.
Thanks in advanced.
Jamessmp23 is offline   Reply With Quote
Old   November 9, 2020, 14:23
Viraj Belekar
Thanks in advanced.
Yes, I solved my case. I had to use a blending model since I have multiple phases. I don't understand what your question is regarding the mass transfer equation. I am using the Frossling model to model mass transfer available in OpenFOAM. You may want to lookup interfacePhaseChangePhaseSystem to understand the solution procedure for mass transfer.
Best,
Viraj
Old   February 15, 2021, 12:17
Sebastián Moreno Cárdenas
smoreno84 is on a distinguished road
I also want to simulate heat transfer between three phases, and mass transfer liquid and gas using multiphaseEulerFoam in OpenFoam V8.
I start executing and the solvers stops at the first iteration without saying anything.
log.multiphaseEulerFoam file and phaseProperties are as attach Files
Can anyone help me with this? I really apreciate your guides. thanks.
Reading field p_rgh
Courant Number mean: 0.01374 max: 0.01374
Starting time loop
Time = 0.001
PIMPLE: Iteration 1
MULES: Solving for alpha.air
MULES: Solving for alpha.water
air fraction, min, max = 0.395966 0.336801 0.590764
water fraction, min, max = 3.05333e-06 0 0.05
Phase-sum volume fraction, min, max = 1.00002 0.909946 1.1632
air fraction, min, max = 0.395963 0.336801 0.590535
water fraction, min, max = 6.0958e-06 0 0.05
air fraction, min, max = 0.39596 0.336801 0.590307
water fraction, min, max = 9.12743e-06 0 0.05
smoothSolver: Solving for H2O.air, Initial residual = 0, Final residual = 0, No Iterations 1
Constructing momentum equations
Tf.airAndWater: min = 325, mean = 325, max = 325
smoreno84 is offline   Reply With Quote
Old   June 16, 2021, 09:26
Kennedy Murithi Micheni
Kenmaster is on a distinguished road
Reading field p_rgh
Starting time loop
Time = 0.001
PIMPLE: Iteration 1
Did you solve this?
Kenmaster is offline   Reply With Quote
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 22:42
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
