October 9, 2020, 06:08 |
transient simulation throttle valve
Hello OpenFoam community,
in order to determine the fluid torque around a throttle disc's axis i want to use OpenFoam. the mass flow rate [kg] as function of the Valve opening [%] as well as fluid temperature and bosst pressure are available as inlet conditions. I want to simulate the throttling process during a given time (50 ms)
which solver would you recommend? should i work with moving mesh/dynamic mesh? is there any useful tutorials using Openfoam in this regard? i would be thankful for any suggestions/ starting Points or even experiences running such Kind of simulations in OpenFoam. Many thanks in advance. |
Steady-state solution as IC for transient simulation | pardoa | OpenFOAM Running, Solving & CFD | 3 | July 24, 2019 07:49 |
udf for valve closing a pipe using dynamic mesh | chem engineer | Fluent UDF and Scheme Programming | 2 | May 13, 2017 10:39 |
Setting Up and Monitoring Transient CFX Simulation | Jack001 | CFX | 3 | April 30, 2016 10:44 |
Transient simulation : Static temperature and time averaged static temperature | saisanthoshm88 | CFX | 4 | July 4, 2013 03:18 |
Simulation of air flow inside valve - FSI? Help! | farianka | Main CFD Forum | 0 | April 17, 2011 17:30 |
