[Foam-Extend-4.1] Parallel run of any tutorial always ends with a mpirun segfaults? |
October 8, 2020, 02:31 |
Sultan Islam
Rep Power: 11 |
Hello everyone,
Does anyone know what this error means? Code:
localhost:09256] *** Process received signal *** [localhost:09256] Signal: Segmentation fault (11) [localhost:09256] Signal code: (-6) [localhost:09256] Failing at address: 0x3e800002428 ExecutionTime = 1498.22 s ClockTime = 1561 s End [localhost:09253] *** Process received signal *** [localhost:09253] Signal: Segmentation fault (11) [localhost:09253] Signal code: (-6) [localhost:09253] Failing at address: 0x3e800002425 [localhost:09257] *** Process received signal *** [localhost:09257] Signal: Segmentation fault (11) [localhost:09257] Signal code: (-6) [localhost:09257] Failing at address: 0x3e800002429 [localhost:09258] *** Process received signal *** [localhost:09258] Signal: Segmentation fault (11) [localhost:09258] Signal code: (-6) [localhost:09258] Failing at address: 0x3e80000242a -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 9253 on node localhost exited on signal 11 (Segmentation fault). -------------------------------------------------------------------------- |
October 11, 2020, 13:46 |
#2 | |
Rep Power: 16 |
I recall that I read that there is a bug in 4.1 when GAMG is used in parallel. Not sure if that is the case here.
October 11, 2020, 18:26 |
Could be
#3 | |
Sultan Islam
Rep Power: 11 |
October 12, 2020, 04:17 |
Rep Power: 16 |
October 14, 2020, 02:28 |
Ah yes GAMG is bugged for parallel
Sultan Islam
Rep Power: 11 |
multiple -parallel cases on single node with single mpirun | mrishi | OpenFOAM Running, Solving & CFD | 1 | June 3, 2019 14:26 |
MPI error in parallel application | usv001 | OpenFOAM Programming & Development | 2 | September 14, 2017 12:30 |
Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
Parallel Run on dynamically mounted partition | braennstroem | OpenFOAM Running, Solving & CFD | 14 | October 5, 2010 15:43 |
