simpleFoam convergence problems, while trying to resolve boundary layer |
October 6, 2020, 08:59 |
Dmitrii Semikin
Rep Power: 6 |
Hello.
I am trying to solve simple sample external aerodynamics problem. The body is a block with one face slightly inclined and all edges and corners rounded. Sizes: 1 x 0.5 x 0.2 m Air velocity: 80 m/s. From this post: How to resolve boundary layer in OF ? I concluded, that to resolve boundary layer I just need to create more dense layers, which I tried to do. When I use mesh with first mesh layer height ~ Y+ = 30 (~ 3.0E-4 m) or more, then solution runs smoothly. But when I try to use mesh with 30 layers, where the first one has height of ~ Y+ = 1 (~ 1.0e-5 m), then the same simulation always diverges. If I look at the picture of the latest iterations before divergence, then problematic faces are located in quite random (from my point of view) place often on the big flat surface. Surface mesh size at this location may be ~0.01m, so the aspect ratio of the layers is not good, but I was sure, that it should not be an issue, because there should be no velocity component normal to the wall... The stacktrace in the log contains the following lines, so I assume, that it is where the floating point exception happens: Code:
[13] #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<double>&, Foam::Field<double> const&, unsigned char, int) const at ??:? [6] #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? In checkMesh log I don't see anything suspicious. And in simpleFoam log one can see, that abruptly the step continuity error explodes and then floating point exception happens. I would highly appreciate, if someone could explain, what could be the reason for divergence. In my understanding, usually it is poor quality of mesh, but in this case I don't see, how it is the case, and what property of mesh is "bad"... Of course, also is of interest, how to overcome this. I tried to decrease relaxation factors and tolerances, but it did not help. Probably some other linear solver could giver more robust convergence? Or some other numerical settings? Thank you in advance. checkMesh log: Code:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 8 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 8-9b73cf21a682 Exec : checkMesh Date : Oct 06 2020 Time : 11:29:53 Host : "openfoam-vm" PID : 4516 I/O : uncollated Case : /data/super-ka-pjt/super-ka/2020-10-05_block-01_06_resolve_boundary2 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 3798462 faces: 22123546 internal faces: 21889090 cells: 9373751 faces per cell: 4.695306713 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 1 Overall number of cells of each type: hexahedra: 0 prisms: 6517632 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 2856119 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology air_y_mid 29554 23007 ok (non-closed singly connected) air_side 269 160 ok (non-closed singly connected) air_bottom 380 223 ok (non-closed singly connected) air_top 330 194 ok (non-closed singly connected) air_inlet 177 107 ok (non-closed singly connected) air_outlet 70 48 ok (non-closed singly connected) car_surf 203676 102087 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-2.964644661 -4.587996649e-14 -3) (10 3.25 3.2) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-2.18097724e-17 7.340355336e-16 -3.994958304e-18) OK. Max cell openness = 1.517392784e-14 OK. Max aspect ratio = 585.8712006 OK. Minimum face area = 6.316036633e-09. Maximum face area = 0.6207478254. Face area magnitudes OK. Min volume = 1.95161539e-12. Max volume = 0.1435894578. Total volume = 261.1931449. Cell volumes OK. Mesh non-orthogonality Max: 55.79104786 average: 9.668060231 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.5989422464 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
... Time = 53 smoothSolver: Solving for Ux, Initial residual = 0.4824992416, Final residual = 0.0427002703, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 0.5263585749, Final residual = 0.01438578753, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.4369752154, Final residual = 0.0368871982, No Iterations 2 GAMG: Solving for p, Initial residual = 0.06624748546, Final residual = 0.003156955786, No Iterations 5 time step continuity errors : sum local = 1.56182585, global = -0.00110296805, cumulative = -0.1549218169 smoothSolver: Solving for omega, Initial residual = 0.08453582241, Final residual = 0.006250842107, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.2660798304, Final residual = 0.01876795111, No Iterations 1 ExecutionTime = 245.59 s ClockTime = 247 s Time = 54 smoothSolver: Solving for Ux, Initial residual = 0.3337720154, Final residual = 0.01002013169, No Iterations 5 smoothSolver: Solving for Uy, Initial residual = 0.3340450882, Final residual = 0.01110384285, No Iterations 4 smoothSolver: Solving for Uz, Initial residual = 0.3731827088, Final residual = 0.009254611244, No Iterations 6 GAMG: Solving for p, Initial residual = 0.8799070613, Final residual = 0.03313636654, No Iterations 2 time step continuity errors : sum local = 893.6400296, global = 0.03382824822, cumulative = -0.1210935687 smoothSolver: Solving for omega, Initial residual = 0.318287741, Final residual = 0.002645842889, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.1526440356, Final residual = 0.00615373916, No Iterations 1 ExecutionTime = 250.03 s ClockTime = 252 s Time = 55 smoothSolver: Solving for Ux, Initial residual = 0.7455203745, Final residual = 0.009375546185, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.7133473046, Final residual = 0.005211766964, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.5544917958, Final residual = 0.0123354264, No Iterations 2 GAMG: Solving for p, Initial residual = 0.3172217772, Final residual = 0.0135137624, No Iterations 4 time step continuity errors : sum local = 3838.404266, global = 3.380422244, cumulative = 3.259328675 smoothSolver: Solving for omega, Initial residual = 0.1870470368, Final residual = 0.01061101629, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.1152355589, Final residual = 0.008423114327, No Iterations 2 ExecutionTime = 254.61 s ClockTime = 256 s Time = 56 smoothSolver: Solving for Ux, Initial residual = 0.445060718, Final residual = 0.02737065041, No Iterations 16 smoothSolver: Solving for Uy, Initial residual = 0.5242167792, Final residual = 0.02489138409, No Iterations 16 smoothSolver: Solving for Uz, Initial residual = 0.4304852584, Final residual = 0.02229787888, No Iterations 16 GAMG: Solving for p, Initial residual = 0.9922608279, Final residual = 0.03727616882, No Iterations 33 time step continuity errors : sum local = 4.971918037e+10, global = -76473931.53, cumulative = -76473928.27 smoothSolver: Solving for omega, Initial residual = 0.2511483143, Final residual = 0.007224566153, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.08664252862, Final residual = 0.006499034169, No Iterations 3 ExecutionTime = 266.15 s ClockTime = 268 s regIOobject::readIfModified() : Re-reading object controlDict from file "/data/super-ka-pjt/super-ka/2020-10-05_block-01_06_resolve_boundary2/system/controlDict" Time = 57 smoothSolver: Solving for Ux, Initial residual = 0.3679538748, Final residual = 0.03369544687, No Iterations 25 smoothSolver: Solving for Uy, Initial residual = 0.5404464887, Final residual = 0.04559830362, No Iterations 22 smoothSolver: Solving for Uz, Initial residual = 0.3205770382, Final residual = 0.02557449322, No Iterations 29 GAMG: Solving for p, Initial residual = 0.9999999995, Final residual = 1.102454466, No Iterations 1000 time step continuity errors : sum local = 3.032927413e+23, global = 1.375129909e+21, cumulative = 1.375129909e+21 smoothSolver: Solving for omega, Initial residual = 0.3376810441, Final residual = 0.01272912993, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.04744437071, Final residual = 0.003486061951, No Iterations 2 ExecutionTime = 433.7 s ClockTime = 436 s ... (stack trace) |
October 6, 2020, 12:31 |
Dmitrii Semikin
Rep Power: 6 |
Minor update:
Now I also tried to map solution from coarser mesh (Y+ = 30) to the finer mesh. And then run the simulation with the fine mesh. But the result diverged on a first iteration... Still no luck . |
October 7, 2020, 05:48 |
Rep Power: 14 |
I haven't come across this problem before, but in response to your question: "which aspect of the mesh is bad?", one answer could be that your aspect ratio is 585, which is pretty high (I know that checkMesh says this is "okay", but it is still pretty high). Alternatives could be that there is a large jump in mesh size between your prism layers and the background core mesh (I can't tell this from just the checkMesh output .... maybe you could upload a picture?).
For fixes, try looking at the gradient and diffusion schemes that you have used in fvSchemes (perhaps upload your fvSchemes file?). For hints on how to make this more stable, take a look at some of the online content by e.g. Guerrero http://www.wolfdynamics.com/training...ession2020.pdf or there's a youtube video of a lecture by Prof Jasak where he gives some advice on solver settings: https://www.youtube.com/watch?v=a4B_oXR5Kzs Good luck, and let us know how you solved it in the end! |
October 8, 2020, 04:42 |
Dmitrii Semikin
Rep Power: 6 |
Hello Tobermory,
Thank you for the links. I will check it out. Meanwhile, here is my fvSChemes and screenshots of the body and mesh attached. with kind regards Dmitrii. |
convergence failure, simplefoam convergence |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 13:41 |
