ERROR in mpirun
Old   October 6, 2020, 06:41
Default ERROR in mpirun
Marco Sala
masal is on a distinguished road
Dear all,
I've a very big problem to run in parallel a boussinesq case with openFOAM.
I want to track the average Nu number in my domain and so on I write a simple functionObjects:
Nusselt_meanFlow
        lib ("libutilityFunctionObjects.so");
        type    coded;
        name    Nu_meanFlow;
        codeExecute
        //look for T and U mean field and assign them to a variable with same name
        volVectorField UMean = mesh().lookupObject<volVectorField>("UMean");
        volScalarField TMean = mesh().lookupObject<volScalarField>("TMean");
        volScalarField nu = mesh().lookupObject<volScalarField>("nu");
        dimensionedScalar nu_avg = fvc::domainIntegrate(nu)/gSum(mesh().V());
and so on...
Then I put it in my controlDict:
 #include "functionObjects/Nu_mean.H"
When I run not using mpirun the simulation is fine and I obtain the results, but when I run in parallel I obtain this error:
Starting time loop
[0] [2]
[2]
[2] --> FOAM FATAL ERROR:
[2] Unknown function type coded
Valid functions are :
6
patchProbes
probes
psiReactionThermoMoleFractions
rhoReactionThermoMoleFractions
sets
surfaces
[2]
[2]
[2]     From function static Foam::autoPtr<Foam::functionObject> Foam::functionObject::New(const Foam::word&, const Foam::Time&, const Foam::dictionary&)
[2]     in file db/functionObjects/functionObject/functionObject.C at line 100.
[2]
FOAM parallel run exiting
[2]
I check the syntax at src/utilites/codedFunctionObjects and it's fine (there's an example). I think that is a problem of mpirun, but i'm new with openFoam and i'm no practice with Linux enviroment.
I'm very stack on this problen and I very need your help.
Thanks,
Marco
P.S. I'm using 5.x version OF
masal is offline   Reply With Quote
MPIrun Problem with FoamJob Workaround kaszt OpenFOAM Running, Solving & CFD 3 October 4, 2018 13:55
mpirun unable to find SU2_PRT Apollinaris SU2 Installation 1 May 10, 2017 06:31
using mpirun EmadTandis OpenFOAM Running, Solving & CFD 1 December 4, 2016 15:29
OF mpirun and parallel problem heksel8i OpenFOAM Running, Solving & CFD 2 September 11, 2013 06:33
MPIRUN fails lfbarcelo OpenFOAM 3 March 29, 2010 08:41
