decomposePar doesn't decompose boundaryFields
Old   October 1, 2020, 04:52
Default decomposePar doesn't decompose boundaryFields
ishan
ishan_ae is on a distinguished road
Hello.
When I run decomposePar on my simpleFoam case it decomposes only the internalField data and not the boundaryField data.
I want to run a simpleFoam case with U internalFields values generated from potentialFoam.
The geometry/mesh/patch names I am using is same for both the solvers.
But I had to simplify the BC for potentialFoam run.
Accordingly, I mapped the U field from potentialFoam runto U/0 in simpleFoam folder.
I want to use this mapped field as values to internalFields to simpleFoam run.
Since I am dealing with large mesh, I copied that data into a separate foamFile callled initialU and its format looks like this:
initialU //name of the field
List<vector>
9528301
(x1 y1 z1)
(x2 y2 z2)
This way I can easily update the BC in U/0 without loading that data every time.
By the way, this foamFile is located in 0 folder.
The U/0 folder looks like this:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
 #include "initialU"
dimensions [0 1 -1 0 0 0 0];
internalField nonuniform $initialU;
boundaryField
    //my boundary conditions
After I run decomposePar on this setup, only the internalField values are decomposed and not the boundaryField data.
The decomposed U file from processor0 looks like this:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      U;
internalField   nonuniform List<vector>
531740
(1.92541 -0.998319 0.87524)
(1.81862 -1.05479 0.762567)
(1.78588 -1.01315 0.756257)
The last two curly brackets are suspicious to me. Not sure what they are closing.
In the original mapped file, i.e. before I did all these shenanigans, the U/0 looked like this:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      U;
9528301
(137.464 -2.17855 -0.202383)
(137.466 -2.17814 -0.20957)
(140.515 -2.36609 -0.160376)
boundaryField
Am i complicating things here ? Can someone please suggest what's going wrong ?
ishan_ae is offline   Reply With Quote
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
Problem with decomposePar (and mapFields) for large problem quarkz OpenFOAM Pre-Processing 2 February 21, 2019 10:51
multiRegion decomposePar should not decompose each region over all processors svenk OpenFOAM Pre-Processing 1 April 11, 2018 06:44
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 09:57
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 06:27
