Implement a non-orthogonal correction on the boundary snGrad
Old   September 28, 2020, 06:37
Unhappy Implement a non-orthogonal correction on the boundary snGrad
anonymous
yyy155klt is on a distinguished road
I’m a newbie to OpenFOAM, and have a problem with implementing a non-orthogonal correction on the boundary.
The reason why I wanted to do so is this forum.
(snGradCorrection)
I tried to modify fixedValueFvPatchField.C and make fixedValue to override snGrad, but a lot of error occurred.
I spent a lot of time on that, but I couldn’t solve it. (It should be involved to usage of member function.)
Does anyone know a solution to this?
I’m using OpenFOAM 6.
Thanks in advance.
yyy155klt is offline   Reply With Quote
Old   September 28, 2020, 07:39
Santiago Lopez Castano
Santiago is on a distinguished road
In my version of FOAM, the fvPatchField<Type> class defiens the snGrad member, which is virtual:
 virtual tmp<Field<Type> > snGrad() const;
Which means you can write your version directly onto any other class derived from fvPatchField<Type>. I suggest you NOT TO MODIFY the fixedValue template class, but just create a copy, and work there.
Santiago is offline   Reply With Quote
Old   September 28, 2020, 09:04
anonymous
Hello Santiago.
I'm very grateful for your fast response.
I suggest you NOT TO MODIFY the fixedValue template class, but just create a copy, and worked there.
I’m very sorry, but I forgot to mention.
I copied “fixedValue” to my src directory ($WM_PROJECT_USER_DIR/src) and work there.
Do you mean that your recommendation is I revise snGrad (implement non-orthogonal correction) not in fixedValue but in fvPatchField?
Actually, I had tried to revise fvPatchField (copied it to my own directory), but I couldn’t compile it.
I replaced “fvPatchField” to “myFvPatchField” and implement non-orthogonal correction to snGrad() in myFvPatchField.C.
(Because “calculatedFvPatchField.H” is included in fvPatchField.H, I added “myCalculated” (copied from “calculated” ).)
Attached log is as shown in this.
wmake libso .
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file myCalculatedmyFvPatchFields.C
Making dependency list for source file myFvPatchFields.C
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/finiteVolume/lnInclude  -IlnInclude -I. -I/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude -I/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OSspecific/POSIX/lnInclude   -fPIC -c myFvPatchField_withCorrection_200927/myFvPatchFields.C -o Make/linux64GccDPInt32Opt/myFvPatchField_withCorrection_200927/myFvPatchFields.o
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100 -I/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/finiteVolume/lnInclude  -IlnInclude -I. -I/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude -I/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OSspecific/POSIX/lnInclude   -fPIC -c myCalculated/myCalculatedmyFvPatchFields.C -o Make/linux64GccDPInt32Opt/myCalculated/myCalculatedmyFvPatchFields.o
In file included from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/typeInfo.H:57:0,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/token.H:46,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/UListIO.C:28,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/UList.C:233,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/UList.H:484,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/List.H:43,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/wordList.H:42,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/patchIdentifier.H:38,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/polyPatch.H:42,
                 from /work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/finiteVolume/lnInclude/fvPatch.H:39,
                 from lnInclude/myFvPatchField.H:47,
                 from myCalculated/myCalculatedmyFvPatchField.H:50,
                 from myCalculated/myCalculatedmyFvPatchFields.H:29,
                 from myCalculated/myCalculatedmyFvPatchFields.C:26:
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/className.H:99:5: error: expected constructor, destructor, or type conversion before ‘template’
     template<>        \
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/className.H:112:5: note: in expansion of macro ‘defineTemplateTypeNameWithName’
     defineTemplateTypeNameWithName(Type, Type::typeName_())
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/className.H:135:5: note: in expansion of macro ‘defineNamedTemplateTypeName’
     defineNamedTemplateTypeName(Type);                                         \
lnInclude/myFvPatchField.H:674:5: note: in expansion of macro ‘defineNamedTemplateTypeNameAndDebug’
     defineNamedTemplateTypeNameAndDebug                                        \
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/fieldTypes.H:52:5: note: in expansion of macro ‘myMakeTemplatePatchTypeField’
     Macro(vector, __VA_ARGS__)                                                 \
lnInclude/myFvPatchField.H:686:5: note: in expansion of macro ‘FOR_ALL_FIELD_TYPES’
     FOR_ALL_FIELD_TYPES(myMakeTemplatePatchTypeField, type)
myCalculated/myCalculatedmyFvPatchFields.C:43:1: note: in expansion of macro ‘myMakePatchFields’
 myMakePatchFields(myCalculated);
     template<>        \
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/fieldTypes.H:53:5: note: in expansion of macro ‘myMakeTemplatePatchTypeField’
     Macro(sphericalTensor, __VA_ARGS__)                                        \
     template<>        \
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/fieldTypes.H:54:5: note: in expansion of macro ‘myMakeTemplatePatchTypeField’
     Macro(symmTensor, __VA_ARGS__)                                             \
     template<>        \
/work/opt/local/apps/gcc/4.8.5/impi/2019.4.243/openfoam/6/OpenFOAM-6/src/OpenFOAM/lnInclude/fieldTypes.H:55:5: note: in expansion of macro ‘myMakeTemplatePatchTypeField’
     Macro(tensor, __VA_ARGS__)
myCalculated/myCalculatedmyFvPatchFields.C:43:32: error: expected constructor, destructor, or type conversion before ‘;’ token
make: *** [Make/linux64GccDPInt32Opt/myCalculated/myCalculatedmyFvPatchFields.o] Error 1
I’m not sure how to solve it.
Thank you very much.
Old   September 29, 2020, 22:33
anonymous
I’m terribly sorry, I failed to attach the files (revised library and log(compile error)) on my last post.
Thanks in advance.
boundary, fixedvalue, non-orthogonal correction, openfoam 6, sngrad
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
