Issue with specifying boundary conditions for supersonic retropropulsion
Old   September 25, 2020, 02:29
Default Issue with specifying boundary conditions for supersonic retropropulsion
dinesh Choudhary
dc2869 is on a distinguished road
I am simulating a supersonic bow shock on air jet from nozzle inlet thrusting into the oncoming supersonic freestream with rhoCentralFoam k-ω SST model. The problem is while running the case simulation crashes at very early stage, i suspect that my boundary condition are incorrect specifically the supersonic freestream boundary conditions. My setup for p, T and U are as below.
p:
internalField   uniform 9831120;
boundaryField
    inlet
        type        totalPressure;
        value       uniform 9831120;
        p0          uniform 9831120;
        psi         thermo:psi;
        gamma       1.4;
    freestream
        type        waveTransmissive;
        value       uniform 13800;
        field       p;
        psi         thermo:psi;
        lInf        0.43815;
        fieldInf    13800;
        gamma       1.4;
    walls
        type        zeroGradient;
    axis
        type        empty;
    wedge1 {type wedge;}
    wedge2 {type wedge;}
T:
internalField   uniform 294;
boundaryField
    inlet
        type           totalTemperature;
        value          uniform 294;
        T0             uniform 294;
        psi            thermo:psi;
        gamma          1.4;
    freestream
        type          zeroGradient;
    walls
        type          zeroGradient;
U:
internalField   uniform (-694.404 0 0);
boundaryField
    inlet
        type           zeroGradient;
    freestream
       type            fixedValue;
       value           uniform (-694.404 0 0);
    walls
        type          noSlip;
totalpressure is set for the nozzle inlet, To complement this boundary condition i use the zeroGradient boundary conditions for velocity inlet, also i don't know the value for velocity at nozzle inlet. The problem is with freestream boundary condition it is having the velocity in negative x-direction opposing the nozzle inlet also the internal field for U is right or wrong, I have attached the image of the geometry .
can anyone please help me out to set proper boundary condition.
dc2869 is offline   Reply With Quote
UDF for Automatic Solution Initialization for previous case data file gartz89 Fluent UDF and Scheme Programming 6 March 30, 2020 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Radiation interface hinca CFX 15 January 26, 2014 18:11
