Hull Simulation Gone Bad
Old   September 22, 2020, 03:03
Unhappy Hull Simulation Gone Bad
yannis_v is on a distinguished road
Hello everyone.
It is my first steps to OpenFoam and CFD in general, after completing a cfd class doing my master's degree. I tried to simulate the flow around a hull and estimate the drag coefficient, using the DTS hull example and a wiggley hull example I located, however both without enough documentation. The boundary conditions are almost an exact copy of the examples, and I made sure that the alpha factor was correctly calculated in zero time.
The mesh created using SALOME.
The code succesfully compiled (interfoam, k-omega), but when postprossecing, i realized that the water was leaving the domain . I tried to attach some photos but unfortunately I was not able, so i included them in a google drive folder (https://drive.google.com/drive/folde...TF?usp=sharing). I also include the 0, constant and system folders.
I suspect that the problem lies at inlet / outlet configuration.
Please help a guy not give up just yet
Thank you all and keep up the good work!
yannis_v is offline   Reply With Quote
Old   September 22, 2020, 10:05
Pedro Pacheco
ptpacheco is on a distinguished road
Yannis, the link is not available...
ptpacheco is offline   Reply With Quote
Old   September 23, 2020, 04:48
I'm so sorry.
Please find below the active link.
Thank you for your assistance once again!
Old   September 23, 2020, 09:50
Pedro Pacheco
Yannis, it seems you have switched the inlet and outlet. This is what is causing your problem: you are setting the velocity in the inlet and intermal mesh to be (8.24 0 0) m/s but since the inlet is the furthest part of the domain along the x axis, the velocity is actually pointing out of the domain.
You can either switch back the inlet and outlet or just put a minus sign on your Umean.
Hope this helps!
Old   September 24, 2020, 06:58
ptpacheco thank you for your time!
I will check and revert as soon as possible!
I hope you have a great day!
newbie
3D wave simulation CFX JimG91 CFX 9 January 2, 2023 01:54
Tutorial: Heave and Pitch Simulation of Ship hull moving through head sea waves Baxter FLUENT 3 May 2, 2019 05:31
Simulation of flow around a ship hull using fluent and Openfoam manoj_nav FLUENT 0 December 17, 2015 02:05
Multiphase Simulation of 26ft planning hull lucasiervolino FLUENT 0 September 27, 2015 18:54
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 23:50
