October 4, 2024, 07:39 |
#21 |
Jacques
Rep Power: 7 |
Sadly i can no longer compile it. I will try to modify the tutorials for simplefoam which did compile.
Making dependencies: buoyantHumidityPimpleFoam.C g++ -std=c++11 -m64 -pthread -DOPENFOAM=2212 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/meshTools/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/sampling/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/transportModels/compressible/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/thermophysicalModels/basic/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/thermophysicalModels/radiation/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/TurbulenceModels/turbulenceModels/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/TurbulenceModels/compressible/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/dynamicMesh/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/dynamicFvMesh/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/regionFaModels/lnInclude -iquote. -IlnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/OpenFOAM/lnInclude -I/clust/softs/OpenFOAM/OpenFOAM-v2212/src/OSspecific/POSIX/lnInclude -fPIC -c buoyantHumidityPimpleFoam.C -o /clust/softs/OpenFOAM/OpenFOAM-v2212/build/linux64GccDPInt32Opt/applications/solvers/heatTransfer/buoyantHumidityPimpleFoam/buoyantHumidityPimpleFoam.o In file included from buoyantHumidityPimpleFoam.C:176: pEqn.H: Dans la fonction «*int main(int, char**)*»: pEqn.H:55:57: error: pas de fonction concordante pour l'appel à «*Foam::fvMatrix<double>::solve(Foam::word)*» p_rghEqn.solve(p_rgh.select(pimple.finalInnerIter())); ^ In file included from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvMatrix.C:3031, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvMatrix.H:1269, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/ddtScheme.C:32, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/ddtScheme.H:391, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvcDdt.C:30, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvcDdt.H:252, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvc.H:46, from /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvCFD.H:6, from buoyantHumidityPimpleFoam.C:43: /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvMatrixSolve.C:318:31: note: candidate: «*Foam::SolverPerformance<Type> Foam::fvMatrix<Type>::solve(const Foam::dictionary&) [with Type = double]*» Foam::SolverPerformance<Type> Foam::fvMatrix<Type>::solve ^~~~ /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvMatrixSolve.C:318:31: note: pas de conversion connue pour convertir l'argument 1 depuis «*Foam::word*» vers «*const Foam::dictionary&*» /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvMatrixSolve.C:343:31: note: candidate: «*Foam::SolverPerformance<Type> Foam::fvMatrix<Type>::solve() [with Type = double]*» Foam::SolverPerformance<Type> Foam::fvMatrix<Type>::solve() ^~~~ /clust/softs/OpenFOAM/OpenFOAM-v2212/src/finiteVolume/lnInclude/fvMatrixSolve.C:343:31: note: le candidat attend 0 argument, 1 fourni(s) make[2]: *** [/clust/softs/OpenFOAM/OpenFOAM-v2212/wmake/rules/General/transform:38: /clust/softs/OpenFOAM/OpenFOAM-v2212/build/linux64GccDPInt32Opt/applications/solvers/heatTransfer/buoyantHumidityPimpleFoam/buoyantHumidityPimpleFoam.o] Error 1 make[2]*: on quitte le répertoire «*/clust/softs/OpenFOAM/OpenFOAM-v2212/applications/solvers/heatTransfer/buoyantHumidityPimpleFoam*» make[1]: *** [/clust/softs/OpenFOAM/OpenFOAM-v2212/wmake/makefiles/apps:28: buoyantHumidityPimpleFoam] Error 2 make[1]*: on quitte le répertoire «*/clust/softs/OpenFOAM/OpenFOAM-v2212/applications/solvers/heatTransfer*» make: *** [/clust/softs/OpenFOAM/OpenFOAM-v2212/wmake/makefiles/apps:28: heatTransfer] Error 2 The tutorials are still not working and I don4t understand how they are supposed to work... The solvers asks (with reason I would say) for a thermo:specificenthalpy in the fvSolution file : how can it work without it ? When I add it, the first iteration for the enthalpy goes to the roof and crashes though. |
Which solver required for humidity and temperature distributiion | Sandy7 | STAR-CCM+ | 2 | January 25, 2017 03:17 |
relative humidity more than 100%!! unable to understand why this is happening | amasugi14 | FLUENT | 1 | December 1, 2015 22:01 |
buoyantPimpleFoam Convergence Issues | joel.lehikoinen | OpenFOAM | 1 | December 5, 2013 15:58 |
Condensation of water if humidity > 100% | Wikie | FLUENT | 4 | November 11, 2010 14:57 |
Condensation of water if humidity > 100% via UDF | Wikie | Fluent UDF and Scheme Programming | 0 | November 9, 2010 17:41 |
